Utv stalling
/ Utv stalling #1
Mfrick01
Kubota 2800
I have a bulldog utv with a Suburu (Robin) eh65 engine. When going over fairly rough cattle guards the engine stalls. Had to sit for 5 minutes or so before it would restart. Also had the problem on a steep incline. Any ideas what's causing this problem?
/ Utv stalling
If it's carbureted, the float level is too low and it's being starved for fuel (provided it's a gas motor).
It is carbureted. Can the float level be adjusted?
/ Utv stalling #4
Take off the bowl and have a look. Usually you can bend the float tab to adjust the fuel level. Fuel level needs to be at the split between the carb body and the top of the float bowl.
/ Utv stalling
Thanks that is helpful.
2014 KOMATSU PC170LC-10 EXCAVATOR (A65053)
2014 KOMATSU...
Year: 2007 Make: Ford Model: F-250 Vehicle Type: Pickup Truck Mileage: 77,977 Plate: Body Type: 4 (A61573)
Year: 2007 Make...
2014 MAC FLAMELESS HEATER (A68842)
2014 MAC FLAMELESS...
2022 LEVEL BEST GB100 108" HYD GRADER BLADE (A65053)
2022 LEVEL BEST...
2016 Peterbilt 579 Wet Kit T/A Day Cab Truck Tractor (A66736)
2016 Peterbilt 579...
2014 Ford Escape SUV (A66738)
2014 Ford Escape...
