UTB Universal 445DT front wheel alignment
/ UTB Universal 445DT front wheel alignment #1
uncle888
UTB Universal 445DT
Hello,
I am looking to confirm that my tractor front wheels are correctly aligned because I have only recently noticed that the inside wheel, when turning a circle, is turned into the circle quite a bit more than the outside wheel.
The tractor is only used on grass and drives straight ahead without pulling to either side although the left wheel, looking from the cab, looks to wobble a bit.
All of this first became apparent after doing some tortuous work and noticing that the front left wheel was not vertical anymore - the four bolts which attach the steering arm to the left hand wheel hub had become loose.
Attached are 3 pictures, one straight ahead (approx.), and one each of full lock.
MacDon 963 Draper Header (A63688)
MacDon 963 Draper...
40' CONTAINER (A63291)
2020 International LT625 48" Sleeper (A62613)
2020 International...
White Metal Roof Vents (A64194)
White Metal Roof...
2016 John Deere 470G Hydraulic Excavator (A64194)
2016 John Deere...
Caterpillar 416-442D Backhoe Service and Parts Manuals (A63117)
Caterpillar...
