using up ignition points on 8N
/ using up ignition points on 8N #21
Forget e-ignition till you are able to care for points.
No such thing as internal resister coil, so not sure what you bought.
A Napa ic14sb is a good coil for 12v. No resistors needed.
Make sure your points gap is correct, too small a gap and they will burn.
Use the correct condenser as well.
Burning points that quick points to a failure in procedure, or incorrect parts, or both.
/ using up ignition points on 8N #22
It's been a while since I've had to deal with points but the way to tell whether it's the coil or condenser is by which side of the points has been arcing or burnt.Sorry I forget which is which .
/ using up ignition points on 8N #23
NEITHER REALLY IS THE ANSWER.
A 6V COIL ON 12V = OVER CURRENT AND THERMAL DAMAGE TO THE POINTS.
OPEN CONDENSOR = ARC BURNS..
/ using up ignition points on 8N #24
If this was a conversion to 12 volts which is what it appears then an external ballast resistor is likely needed as the coil one is not enough.
These are white ceramic things. You wire them so that when the ignition key is turned to start the resistor is by passed and then in the run position the power to the coil flows through the resistor reducing the voltage and burning up of the points.
Here is a link to show you what they look like.
http://www.autopartsway.ca/part.cfm?8214/m46&g=1&gclid=cj7nt5jv-socfqktaqodh80exw
Dave M7040
/ using up ignition points on 8N #25
N don't have key to start ignition switches, they are on and off, and there is a separate button on the trans to run the starter relay, or mechanical switch.
A 52 8n had a 6v coil and no resistor.. Swapping to a 12v coil is a good fix. No extra connections for a resistor, and no guessing the value of the resistor needed. Plus, ok coil could probably use a refresh anyway. Napa ic14sb is a 16$ coil that works fine.. No resistors.
If you don't know anything about the application, you might want to limit your responses to what you know, so that you are helping the issue, not adding to it.
/ using up ignition points on 8N #26
Dave, even with the proper 12V coil you need to run a resistor wire or ballast resistor to feed the coil or the points will burn up in short order.
The points only see a full 12V during the starting circuit as the resistor is bypassed.
To answer the previous question, you will see around 6 V on the positive terminal of the coil while the engine is running, on a 12V system.
/ using up ignition points on 8N #27
Sorry, your answer is 100% incorrect, and is bad info.
Ic14sb coil run with no resistor on 12v.
Go back to school...
There are no starter bypass relay on N!!
Please don't offer advice if you have 0 knowledge of the application! :(
/ using up ignition points on 8N #28
Go back to school... ;)
I don't care about the coil... The points will not last.
/ using up ignition points on 8N #29
You are just plain wrong.. Sorry.
/ using up ignition points on 8N #30
Finish this tomorrow. Busy tonight
/ using up ignition points on 8N #31
I knew a fella that hooked up his battery backwards and was burning out points until some one pointed it out to him? At least that's what he told me.
/ using up ignition points on 8N #32
that's pretty much 100% BS too. There's some other part of the story thay are not telling you.
apparrently there is some huge lack of understanding of basic electronic concepts AND how a kettering ignition system ACTUALLY works.
at the root, you have a battery, a coil with a primary and a secondary, and breaker points, and a condensor.
power from bat thru coil and closed breakers . IE.. primary current flow. mag field charges, breakers open, mag field collapses, induces a voltage on the secondary which is the high voltage discharge. Breakers are still opening and close enough to arc, so the condensor acts as a switch debouncer for a few moments untill the point gap widens. rinse and repeat.
too small a points gap and they never open enough and will arc and burn.
open condensor and the points will arc and burn
shorted condensor and the points will never actually open, as the condensor is across the contacts, and that just leaves you with current flowing in the primary circuit... leading to eventual thermal damage of the coil, dead battery, and non running engine.
oil/grease ont he breaker contacts will cause arcing and burning
too much primary current ( 6v coil in a 12v system ) will lead to reduced points life due to thermal damage and excessive metal transfer and pitting of the breaker contacts.
too little primary current ( 12v coil in a 6 v system, or a 12v coil in a 12v system PLUS some ballast resistor added in because the users doesn't know electronics ) yeilds no spark, or very weak spark.
Lastly, ultimate voltage of the spark at time of arc is defined by the size of the arc gap, and the physical characteristics of the atmosphere of the cylinder in which it is firing. In other words.. if doesn't matter whether you buy a stock coil or one of the fancy ones that claims 80,000v... the spark will still jump at say.. 9000v, if the arc gap and physical atmospher of the cyl allow it to do so... thus using stock plugs and gaps, you NEVER see the inflated claims made by some components.
It pays to actually know a little bit about this stuff.
As for the backwards battery / reversed polarity. it makes a LITTLE difference. the biggest difference can be measured ONLY with an electron microscope, and a very expensive, very sensitive piece of industrial grade equipment.
The issues? metal transfer direction of the breaker contacts. SOME contacts are set for a polarity, and have different coatings on each of the breaker contacts. .. Mostly these days, they are ALL the same, both sides.. so this part makes little difference. ( you might have seen this in some mechanical voltage regulators that ware also marked with a polarity preference ).
secondly, you can get a big resistance vs a big resistance plus a little resistance issue on the coil if ran at incorrect polarity.
take a typical 6v coil that needs no ballast resistor. primary impedance ( kinds like dc resistance ) can be around 1.5-1.8 ohms. the secondary may be 4000-8000 ohms.
If you have a polarity mismatch on some coils, you may be seeing a 4000+1.5 vs 4000.. IE.. not much difference. some applications this is difficult to correct.. like the ford 9n/2n/early 8n front mount coil.
Notcie the voltage and impedance relationships. your target primary current is usually somewhere around 4 amps a little more or a little less, depending... usually less.
when you see a ford front mount coil/tractor that is 6v, it also uses a ballast resistor. but when you see a ford 6v coil / side mount.. it does not use a ballast resistor.. why? coil impedance. the front mount is not a 1.5-1.8 ohm coil. it is a .9-1.2 ohm coil.. thus it needs a ballast resistor inline with it to maintain a correct primary impedance and thus primary current. without it, primary current would be 5-6 amps or more. the side mount coil already has the 1.5-1.8 primary it needs due to the way the coil was designed.. the correct number of turns of the correct sized wire. Move up to the 12v fords in the 65+ range... they used a resistor wire, and a 6v coil, and a bypass relay. Relay put full voltage to the coil when starting, because full voltage won't be 12v when starting due to increased starter demand from the larger engines, and the still anemic battery technology of the day., once started, the resistor was no longer bypassed, and thus you have a 6v coil, plus resistor, running on 12v. primary impedance and primary current were both happy.
That's the basics of the why and how of it.
/ using up ignition points on 8N #33
I'd think you can still get an electronic ignition replacement for points. I had an Alfa Romeo that ate points. Got a kit way back then that was just a sensor that bolted the same place as the point mechanism did. The sensor could read the high points on the came lobe to tell when to fire. Of course, you could rotate the distributor to get the right advance, etc. Don't recall what it was but I'll bet you can get a system on line.
My Alfa always would sit there idling very smoothly after going mile after mile. Before, after 1,000 or so miles, it would idle roughly and would cut out when revved, and you really needed to rev that 1,300 cc engine.
Ralph
/ using up ignition points on 8N #35
Ralph
Pertronix ( and a couple others ) make EI kits. there is a magnetic ring that you slide down on the dizzy shaft, and then a hall effect sensor kit.
If your alfa ate points, it was because of one of the reasons I mentioned above, or some mechanical issue like non square striking points., etc.
/ using up ignition points on 8N #36
You know what's hilarious. I can't find specs in this magical coil because a Google search only pulls up your eight million posts on the same subject.
You're as big of an *** in all of those as well. Thumbs up!
/ using up ignition points on 8N #37
.... and pertronix kits suck....
/ using up ignition points on 8N #38
Gee, that's weird, I just did a Bing search on:
Ic14sb ign coil
1st hit was Napa, and it showed price, volts, and a specification page ( that had not much more than volts and mounting )
2nd hit was a reseller, also listed voltage.
As for pertronix kits? I don't care for ei, I have no trouble maintaining points.
I do have a kit on a farmall c, just because it was free.
It starts just as good as my points tractors. No way I'd pay 70+$ for a kit when good points cost 10$ and can last decades and don't die If you put the battery in backwards.
As for your opinion of me, what can I say? I'd rather be a smarta** than a dumba**.
So.. Lets do the tally real quick.. Hmm.. Looks like my info was correct... Soo.. I guess since I got the smarta** position.. Looks like you are stuck with the other one? Darn.. Tough luck.. Good luck next time! :)
/ using up ignition points on 8N #39
I am responding only so I can continue to see the discussion......
:D
/ using up ignition points on 8N #40
wp_ss_20160216_0001.pngFor the " show me " people, here is a good pic of the coil from eBay.
Clearly states no resistor required.
Also, for those that haven't figured it out, ic 14 costs more, the 'sb' line is the economy line.. No yellow paint...
2020 Freightliner M2 106 AWD Altec DC47TR Digger Derrick Truck (A60460)
2020 Freightliner...
2011 Ford F-350 Service Truck (A62613)
2011 Ford F-350...
John Deere 4040 Tractor (A64047)
John Deere 4040...
2006 MACK VISION (A65643)
2006 MACK VISION...
2002 Kenworth T300 TMA Attenuator Truck (A64194)
2002 Kenworth T300...
213085 (A64276)
213085 (A64276)
