Using Tractor Hydraulics for Log Loader Trailer
   / Using Tractor Hydraulics for Log Loader Trailer #1
Dirigo54
Western Maine
John Deere 6220
I have a John Deere 4 wd 6220 with an closed hydraulic system. I also have a Hardy 1700 ST log loader trailer with a open hydraulic system. I am hoping to run the trailer hydraulics off the tractor system. Loader requires 8 gal/min and 2500 psi. Tractor runs 20+ gal/min and 2900 psi. Have not been able to get a good answer from local dealers. Might have to run a pto pump instead of using tractor hydraulics? Supposedly there is a kit that will create a free return line for an open system. Has anyone used this or know much about it? Hard to get good information...
Thanks!
   / Using Tractor Hydraulics for Log Loader Trailer #2
Might have better luck asking this in the Hydraulics forum where J J hangs out.
Thanks, I just posted it there as well.
   / Using Tractor Hydraulics for Log Loader Trailer #4
Have you checked if you can convert the valve to an closed center?
On many valves that are kits to do that.
2007 Brunswick Challenger 27ft Fire Rescue Boat with Tri-Axle Boat Trailer (A50324)
2007 Brunswick...
2019 Ford F-350 XL (A50120)
2019 Ford F-350 XL...
2018 GMC Sierra 2500 4x4 Crew Cab Pickup Truck (A50323)
2018 GMC Sierra...
2023 Deere 331G (A50120)
2023 Deere 331G...
2018 Ford F-150 4x4 Crew Cab Pickup Truck (A50323)
2018 Ford F-150...
2007 BobCat S175 Skid Steer (A52384)
2007 BobCat S175...
