using oil
/ using oil #1
stacey trest
2022 6075 mahidra
215 hours on a2022 6075 mahindra when put under aload it uses alot of oil but runs great
/ using oil #2
welcome to this forum. please describe the problem in detail, is this sudden or always occur? is the smoke blue, black, or white? how much oil consumed? have you done the initial break in service? what oil are you using? any leaks?
more details needed,
best regards & welcome
/ using oil
started all of a sudden black smoke but not a lot. No leaks, Rotella oil. Filled with oil this morning, started bushhogging at 6 o'clock at 8,30 the low oil buzzer was coming on, and the oil was below the add mark. Just got it out of shop yesterday for same thing . they said it was the turbo ,but i guess not
/ using oil #4
OP: let us know the outcome of your tractor woes. Still under warranty? good luck
/ using oil
thanks, yes still under warranty. Jest thought this might have happened to someone else.
/ using oil #6
what was dealer's take on it, & the current status of diagnosis?
/ using oil #7
Bad turbo oil seals would have been my first thought. Did the dealer remove the turbo and check?
2015 Dodge Charger Sedan (A61574)
2015 Dodge Charger...
2022 EZ-GO ELITE...
2003 Proclaim Tanker Trailer (A64194)
2003 Proclaim...
New/Unused Quick Attach Backhoe Attachment (A65583)
New/Unused Quick...
SELF-PRIMING CENTRIFUGAL PUMP (A65643)
SELF-PRIMING...
2004 Cadillac Eagle Ultimate Hearse, Eagle Coachbuilders, Hearse Collector Special (A63689)
2004 Cadillac...
