using hay equipment with DK50
/ using hay equipment with DK50 #1
whitmerlegacyfarm
Central PA
2010 Kioti DK50SE HST w/ 401 Loader
Hey all. wats everyones thoights on me using my dk50 to pull a small square baler? im interested in making our own hay since we have 15 acres of fields that i just waste fuel brush hoggin? i just lookin to pick up an older baler n rake. i hav old sicle bar my pap kept in great shape. thanks all. im new to this farmin stuff.
/ using hay equipment with DK50 #2
I am not familiar with the square balers but I used to bale hay with an AC that at every hill the front wheels came off the ground and I had to use the brakes to turn. The 50 horse power I would think would bale hay and you will need a rake if using the sickle bar. My biggest thought is the hay what is the quality of what you have been cutting?
/ using hay equipment with DK50 #3
I used to bale with a JD 14T and a 22 hp Yanmar. I pulled a flat rack behind the baler, too. If the ground is relatively flat, you won't have any problems.
/ using hay equipment with DK50 #4
/ using hay equipment with DK50 #5
I know someone using a newer DK45 to pull a JD 14T baler. Does good, but say a 50 may do a little better. It is their main hay tractor.
/ using hay equipment with DK50 #6
A square baler shouldn't need much tractor at all.......we used a 52 HP tractor to run a 4X5 round baler for years.
Cutting large fields of hay fast with big modern mowers is where you really need HP because you can put heavy loads on the drivetrain for sustained periods of time. We have an old 62 HP MF/perkins that needs rebuilding due to mowing hay......but it took 10,000 hours.
Most of the old sickle mowers were designed for smaller tractors.....your 50 HP tractor should be complete overkill for baling 15 acres with small hay equipment.
/ using hay equipment with DK50 #7
I operate a Massey Ferguson 124 baler (2-twine small squares) with my 2008 Mahindra 5525 (54 hp engine, 45 hp pto) with no problem. The 5525 is heavy enough that you barely feel that baler doing it's thing back there.
/ using hay equipment with DK50 #8
We just had a Revolutionary war reenactment right close to my store. My cousins hosted it. (second largest one in the US) anyhow I got a call to help out with a broken round baler and to my surprise, As I drove up I saw a lil orange tractor pulling a new Holland square baler!
As I got closer....sure enough a Kioti CK25:shocked: Yes it was pulling and dropping square bales! Wow!
Wish I had my camera. It was one of my customers, so I did tell him we needed pictures.
/ using hay equipment with DK50 #9
Just check the hp (requirements of the implement). Older small square bailers can run with minimal power. Round bailers, on the other hand, especially anything over 4x4 and net wrappers require serious power. Newer small square bailers also require power. Example, my 575NH high capacity square bailer requires 75 PTO input for maximum production. That's not to say that you can't run with less but in heavy windrows, it requires more power. A 575 would really load your engine and possible cause damage.
Other problem is if you bale squares with a wagon on the bailer, you need a tractor with enough weight to safely pull the bailer and wagon plus the flunkies loading the wagon. A 4000 pound tractor pulling a 3500 pound bailer plus a 4000 pound almost loaded hay rack is asking for big trouble, especially on hilly ground.
You don't pull a tandem axle equipment trailer with a Volkswagen Jetta. It's all about common sense and safety.
/ using hay equipment with DK50 #10
for 15 acres you can just drop the bails then pick them up no need to form a train
/ using hay equipment with DK50 #11
Mahindra's must be tanks. With my 575 behind the M9, I can 'feel' the plunger if the baler isn't in line, that is going down a windrow. If it's sitting at an angle. it rocks the tractor back and forth.
/ using hay equipment with DK50 #12
We have an old 575 hayliner........the 52 and 62 HP tractors we've had pulled it with ease in fertilized Bermuda hay raked into the proper sized windrows.
/ using hay equipment with DK50 #13
Mine is 9 years old. NH rates it at 75PTO input and it takes every bit of that in wheat straw and/or alfalfa. I have the extra wedges plus the adjustable doors on the bale case and the hydraulic constant tension...a real life saver.
Proper sized windrows to me are whatever yields a bale every 12 feet or so. It's all contract work so the faster, the better and it's all on the ground via a quarter turn chute, 14 slices a bale.
/ using hay equipment with DK50 #14
While I'm sure the HP is nice doing contract work the OP can certainly cover his 15 acres with his current 50 HP tractor no problem with a 575 sized or smaller square baler.
/ using hay equipment with DK50 #15
I bale with a NH 311 on my little Ford 2110 which is only 38 HP and 34.5 at the PTO. It does the work no problem. In really heavy hay make the windrows smaller or use a slower gear on the tractor to keep the RPM up. For your size of operation speed should not be the issue. Focus on safety and the long term health of your equipment.
By the way I plan to try my new DK 50 SE on the Baler next time. With equipment break down last week (and the first hay of the year) I didn't want to try something new so I just used the Ford for the baler. I will let you know how it turns out.
/ using hay equipment with DK50 #16
I agree, to a point and that is, with an underrated power unit, the operator needs to be cognizant of windrow preparation. The windrow needs to be sized in relationship to the available PTO power. In other words, don't push it. Run at rated (540 pto) rpm but don't attempt to crowd the pickup/accumulator with large windrows and high travel speeds. The lower PTO powered tractor won't perform in that condition.
The 575's all have a multi plate front clutch assembly designed especially for higher power, power units than allows slippage when the bailer is operated at maximum capacity Mine gets pretty hot when I push it. Breaking torque (on the clutch) is somewhere around 190 foot pounds. If it's set properly (and not frozen), it's unlikely you'll break a shear (flywheel) bolt unless the knotter gets out of time or something gets picked up in the accumulator and wedges in the bale knife. I check the breaking torque every spring, prior to first cut bailing as well as the breaking torque on all my other clutches. Nothing worse than a frozen clutch and an object in the bailer/mower. That clutch is there for a reason.
I would suspect that with a smaller power unit, the shock load of the plunger operation would eventually take it's toll on the clutch and driveline of the tractor. The 575 pounds pretty hard.
/ using hay equipment with DK50 #17
We always just ran in a low range.
/ using hay equipment with DK50 #18
My 575 (at least) likes a 14 slice bale so I try to set my ground speed so at 540 I'm running 14 slices which equates to 3 mph or high gear on the intermediate range on the M9.
I've never used the 105. It's reserved for the BR round bailer.
I considered a wagon hitch when I got the bailer but I don't believe there is any way you could keep up, loading a hay rack and we have some very efficient loader people here.
Second and subsequent cuts have to be double windrowed to keep the bailer content.
I may b goin to look at a old nh model 66 baler today. Guy has OM n says will show me it bales asking 700. Mite miss 1 in 200 bales if it kept greased. Old but works well he said.
/ using hay equipment with DK50 #20
That's a fair price. I just sold my ancient 66 hayliner to a private party north of here for 500 bucks, just what I paid for it 15 years ago. Considering inflation and the devalued currency, I lost a bit of cash but it went to a good home.... and it bailed very well. A nice bailer for a limited acreage. Not a bailer to run on contract for bottom line.
A 66 can develop knotter stack issues if not greased daily. and the wiper arm MUST PHYSICALLY CONTACT THE LOWER BILL HOOK to wipe the knot.
The 66's also have the old style riveted on twine knives and peened over follower ball stubs. The bronze follower (cam) balls will most likely be flat spotted and need replaced. That's why it misses. The wiper arm will need to be removed, the head ground off and the balls replaced. Balls are stock items at a dealer and the refit kit includes a capscrew that you'll have to drill and tap the stub shaft for. be sure to apply a dab of blue loctite th the threads when installing.
The twine knifes should be replaced at that time as well. The original ones are rivet on, the replacements are bolt on. Just grind the rivet heads off, pop off the old knife with a small screwdriver (note the position on the twine guide foot in relationship to the knife as it has to go back the same way it came off) and rreplace the knife and guide and secure it with the supplied (in the kit) button head screws and nuts.
After that, replace the wiper arm in the cam plate and knotter (apply some grease as you insert the shaft in the knotter casting and under the bronze ball) and then BEND the wiper arm to just contact the bill hook as it passes it. The wiper arm is malleable steel and bendable. The crescent cutout in the wiper HAS TO CONTACT THE BOTTOM OF THE BILLHOOK, PHYSICALLY TO WIPE THE KNOT. That is the biggest reason older bailers miss. the knotters stack becomes sloppy with age and use and the wiper passes too far from the billhook, That leaves the twine in the jaws and as the next bale gets formed, it stretches the twine to the point at which it breaks. You think it misses but in actuality, it's breaking the already formed knot, not missing.
Finally, forget the sisal that the bailer originally ran. Get some quality (nrw stock) 170 poly and run that. The older twine discs (double disc) run 170 just like sisal and the 170 is a superior twine in all respects.
Old bailers are like old women, they need to be coddled a bit to 'perform' properly.:D
New/Unused Landhonor Air Impact Wrench (A61166)
New/Unused...
CATERPILLAR 140 AWD MOTORGRADER (A63276)
CATERPILLAR 140...
2019 GENIE GS-1930 ELECTRIC SCISSOR LIFT (A62129)
2019 GENIE GS-1930...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2011 Jeep Grand Cherokee AWD SUV (A61569)
2011 Jeep Grand...
2001 Peterbilt 379 Tri-Axle Dump Truck (A59230)
2001 Peterbilt 379...
