Using DR PTO trimmer on Cat 2 Tractor?
   / Using DR PTO trimmer on Cat 2 Tractor? #62
The thing I was curious about is the side swing wide enough to do any good using a larger cat 2 tractor? I can see it helping with a narrow tractor but would be more keen on the idea of a wider offset or reach.
   / Using DR PTO trimmer on Cat 2 Tractor? #63
From the Q & As on the DR Website:
"The maximum distance from center of tractor to center of the cutter h[e]ad is ~43". This distance will decrease when cutting on inclines. With the cutting width being 22" in diameter, this makes your cutting range roughly 32" - 54" from the center of your tractor when the trimmer is sitting level."
"Maximum wheelbase, 80" to outside of tires." In this case they obviously mean width of the wheels, not wheelbase.
Terry
   / Using DR PTO trimmer on Cat 2 Tractor? #64
Terry
So on a 72" wide compact such as I have that would be a maximum of 18 inch reach not very much imo. With a larger cat 2 tractor it could barely reach the edge, just something to keep in mind.
   / Using DR PTO trimmer on Cat 2 Tractor? #65
That depends on how far over you can swing the 3 point hitch to offset it...
Aaron Z
Aaron Z
In fact I did get a few more inches when I fiddled with the hitch. I'm pretty sure that looking in the rear view mirror I was seeing the entire cutting head and then some on my 72" tractor.
   / Using DR PTO trimmer on Cat 2 Tractor? #67
Slimcity9;
We are considering it for cutting around stock tanks (ponds). Does it throw cuttings toward tractor or away from tractor? It would not be optimal to throw cuttings into the tank. What is direction of rotation of cutting head when viewed from above?
Thanks
Rick
   / Using DR PTO trimmer on Cat 2 Tractor? #68
You would be more or less mowing what you just drove over with a large cat2. It looks to me like these are mostly for compact tractors. Which is fine by me, my garden tractor doesn't see much use once the garden is in anyway. This would give it something else to do later in the year. Maybe DR will some day come out with a larger version.
   / Using DR PTO trimmer on Cat 2 Tractor? #69
Slimcity9;
Thanks
Rick
While I like the concept of this new DR product I think it would need more reach to do you much good. This trimmer might work fine trimming a fence row with a small tractor but the reach is too limited for pond banks or ditch trimming.
   / Using DR PTO trimmer on Cat 2 Tractor? #70
We only need to cut last 12-18" around tanks. This is as close to edge as I want to get with any of our tractors.
2015 DRAGON 137BBL DOUBLE CONICAL VACUUM TRAILER (A58214)
2015 DRAGON 137BBL...
2017 Chevrolet Trax LS SUV (A55973)
2017 Chevrolet...
2012 Vermeer V500LEHD Vacuum T/A Towable Trailer (A55973)
2012 Vermeer...
2018 Elgin Broom Badger Sweeper, Kubota Turbo Diesel Engine, mounted on 2018 Isuzu NRR Truck, VIN (A59076)
2018 Elgin Broom...
Club Car Carryall 2 Electric Utility Cart (A55851)
Club Car Carryall...
2008 VIKING TRAILER 40+5 LOADER TRAILER (A58214)
2008 VIKING...
