using atv snowblade on 2320
/ using atv snowblade on 2320 #1
purpony
CT
JD 2440/JD 3020/JD 314/JD 345/JD 850/JD 2320
I know an atv snowblade is pretty light duty but I have a next to new 60" blade off my atv that is just sitting and i would like to put a blade on my tractor FEL for the tilt side to side to make plowing my paved driveway a little faster. My tractor is a 2320 so its roughly 1000lbs more then my atv was. I am thinking it should do the job just fine, was just wondering what others had for input before i start this project.
my plow is the blade one pictured-
/ using atv snowblade on 2320 #2
Afternoon Purpony,
I think the light duty blade will be fine as long as you remember your using a piece of equipment thats light duty !!! Your tractor is heavier with more power and I dont think it would be a stretch to bend it ! With that in mind, the proper hookup from the blade to the QA is important. Maybe some added bracing will provide some extra strength in the right
places ! Good Luck and keep us posted ! :)
BTW, there are a bunch of guys on here that are really great fabricators, if you could provide some additional photos of the backside of the blade and tractor Im sure they could make some great reccomendations !
/ using atv snowblade on 2320 #3
Just be carefull... that may become a pretzle pretty fast if you try to put much hp behind it and it finds a particularly stout spot.
soundguy
/ using atv snowblade on 2320 #4
I have an old 48" blade I was thinking of using off my quad. I bought a rear blade instead of hasseling with the fab.
/ using atv snowblade on 2320 #6
I think the plow blade would work out fine. You might find some twisting stress if you are only pushing on one side or the other, but if you are pushing snow across the full blade, I am sure it will work out fine (especially with the trip springs)
Regardless of how heavy the machine (or truck), momentum often does much of the work. I have driven highway plows where 45,000 lbs of truck and plow will pretty much over power most drifts. But that same truck at low speeds on wet deep snow is sitting on top of ice will spin the dual'ies from a slow start.
Keep the momentum up and avoid trying to muscle through the tough spots and I bet you will be fine.
Be sure to share the fab mounting picks
its been a while but here is my atv plow setup-
I didnt get a chace to get the hydraulic side to side tilt done yet, looks like that will be a spting project. Overall though the plow setup works great. Only downside (which i knew before i even started) is the plow is only 52" wide.... but i solved that the other day by purchasing a new 72". It will bolt directly to the frame i have which again is a modded set of atv push tubes. I also plan on welding a could horizontal angle iron pieces on the back side o the plow to make it stronger. Nice thing about this blade though compared to using a truck plow is, its super lightweigh so in the warm months i can move it around my myself and store it anywhere, compared to a 600lb plow.
the green front frame i made is also used for this-
here is the frame that i made for my tractor front end loader. It has the same factory quick detatch as the bucket. Its an all in one frame that gives me a front mounted quick 3 point hitch, front forks, and a snowplow.
with the 3point hitch i can lift my rear mount mower for cleaning, sharpening blades, and moving for storage.
Drive up and tilt
Quick 3point attachment
lift, clean, and sharpen
Quick Hitch, can be used front or rear
Original style quick hitch to front end loader, same as bucket. One and off in uder 10 secs.
Bar pulls out and quickhitch removed. Bar also holds adjustable fork inplace
Quick hitch mounted on rear, backup, hookup, drive away
still got to paint the forks- still looking for a 36" pair as well.
/ using atv snowblade on 2320 #10
That looks absolutely fantastic. What great versatility--it is nicely utilitarian and practical in design and function. :cool: :cool:
Mike
/ using atv snowblade on 2320 #11
That is an awesome system you have there. I would love to do the same thing to my 2350. Is there a way to attach a plow right to the bucket. Clamp it to the bucket or something like that.
/ using atv snowblade on 2320 #12
Purpony,
Outstanding work!
I would love to build one of those too. Are those quick attach mounts available as separate pieces from John Deere? If so, do you have the part number handy?
The ***** end of the 2320 looks a little light with that mower hanging all the way out there....
Runner
Thanks-
yes, the quick hooks and pins can be orderd through JD-
W43359 HOOK, BUCKET
W47211 PIN, BUCKET
yes, with the mower up front the rear is a little light, next time ill put some wait back there. Looking at your pic, are you using a rear mower as well?
/ using atv snowblade on 2320 #14
Thanks for the info. Again, great looking project.
UNUSED 2023 VOLVO ECR25 ELECTRIC EXCAVATOR (A60429)
UNUSED 2023 VOLVO...
2001 Dorsey 48ft Flatbed T/A Trailer (A56857)
2001 Dorsey 48ft...
2021 CATERPILLAR 299D3XE SKID STEER (A60429)
2021 CATERPILLAR...
FORD 3000 TRACTOR (A60430)
FORD 3000 TRACTOR...
LOT LOCATIONS (A59904)
MULCHER (A58214)
MULCHER (A58214)
