Using a Tilt Grade Ditching Bucket
/ Using a Tilt Grade Ditching Bucket #1
bsekf
WNY
Kubota 7030, Long Landtrac 4700, Mahindra 5155
Do these 15 hp Excavators have the power, weight and ability to handle a tilt grade bucket for ditching and cleaning ditches?
/ Using a Tilt Grade Ditching Bucket #2
NO based on the information you have provided in your question.
I am using a back blade angled and tilted and have to move the waste across the road with the back blade and FEL. An excavator with a tilt bucket would be neater. 10 foot road is 1/2 mile up and across a very steep hill. Ditches need cleaning yearly.
/ Using a Tilt Grade Ditching Bucket #4
I picked up a 800mm (31 inch) smooth bucket for road ditching work with my Typhon Terror X 1-ton. Used it to clean out about 200ft of ditch last week. Worked fine and did not require any tilting mechanism. Since it was just cleaning and not really breaking new ground there was not much stress on it. For digging a new ditch I would want to use the smaller tooth bucket and operate like I was trenching.
My technique was to run along the road and dig from the side as I went, rotating and dumping into a skid steer bucket so as not to put debris on the road. Would have gone quicker with another person to operate the skid steer or if I had a dump trailer.
/ Using a Tilt Grade Ditching Bucket #5
Ok, thanks but I was looking for info on what brands of 15 hp excavators you were considering BUT bottom line still no since a 15 hp machine does not weight enough to lift a ditching bucket of any size much less a loaded ditching bucket. Add the assembly for tilt for approx another 50 pounds. My 30" ditching bucket weighs 355 Lbs empty, add another 50 Lbs for tilt and your over 400 Lbs empty. The 30" bucket holds 0.15 struck cubic yards. Swinging this at 12 feet out is enough to unsettle the 10K+ pound M59.
The Kubota KX018 at 16 hp and 3748 to 3968 lbs is too light to handle what your asking to do.
Hope this helps.
/ Using a Tilt Grade Ditching Bucket #6
Using a wide, tilt, grading bucket......
A Rhinox HD 36” smooth grading bucket designed for a KX018 is advertised to weigh 95.2 lbs (excluding the tilt assembly)
Here’s a U17 (slightly less capacity then the KX018) with the Rhinox 36” bucket (no tilt)
/ Using a Tilt Grade Ditching Bucket #7
I have a kubota kh-41 (1990s era) 19hp machine. A month ago I got a 31in tilt grading bucket. The tilt lock ability of my machine isnt great. However the ability to scoop and move 31in of material is wonderfull. I have really hard rocky clay and it will fill the bucket in two scoops.
These smooth buckets work really good for doing patios too.
