3-Point Hitch Using a tiller with early 8N tractor
   / Using a tiller with early 8N tractor
Here is a picture of the manual for a AC 2 way plow. It had both right and left hand plows so you could turn around at the end of the field, change plows and then plow the other way.
   / Using a tiller with early 8N tractor #23
You presume correct that an 8N doesn't travel near slow enough to operate a tiller SUCCESSFULLY unless it's equipped with a gear splitter.
Not sure of all the options but all the "gear splitters" I have seen on the 8n's split before the PTO. Reduced wheel speed results in reduced PTO speed. I assume there is something out there to do what you want but at what cost? Depending on how much you are doing a plow and harrow might give you good results and its more fun!!!
Tafe 45DI (A53317)
Tafe 45DI (A53317)
2019 Peterbilt 520 Trash Truck (A55973)
2019 Peterbilt 520...
2020 FORD F250 XL EXT CAB TRUCK (A57192)
2020 FORD F250 XL...
Kivel Quick Attach Forks (A56469)
Kivel Quick Attach...
2015 Ford F-350 XL (A53317)
2015 Ford F-350 XL...
2016 PETERBILT PB337 FLATBED TRUCK (A52706)
2016 PETERBILT...
