3-Point Hitch Using a tiller with early 8N tractor
   / Using a tiller with early 8N tractor
Here is a picture of the manual for a AC 2 way plow. It had both right and left hand plows so you could turn around at the end of the field, change plows and then plow the other way.
   / Using a tiller with early 8N tractor #23
You presume correct that an 8N doesn't travel near slow enough to operate a tiller SUCCESSFULLY unless it's equipped with a gear splitter.
Not sure of all the options but all the "gear splitters" I have seen on the 8n's split before the PTO. Reduced wheel speed results in reduced PTO speed. I assume there is something out there to do what you want but at what cost? Depending on how much you are doing a plow and harrow might give you good results and its more fun!!!
Push Mower (A55973)
Push Mower (A55973)
2015 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A55852)
2015 Chevrolet...
2009 Honda Pilot AWD SUV (A53424)
2009 Honda Pilot...
2019 KUBOTA SVL95-2S SKID STEER (A52707)
2019 KUBOTA...
2014 Ford Explorer AWD SUV (A55853)
2014 Ford Explorer...
2015 Ford Escape AWD SUV (A55853)
2015 Ford Escape...
