Using a shop press - tips & tricks
/ Using a shop press - tips & tricks #21
/ Using a shop press - tips & tricks #22
I hope I am not speaking out of turn, for pressing bearings the first thing you need is a set of bed or arbor plates long enough to go across your press. these need to be at least 1 inch thick and exactly the same size. they really need to be sized in a mill. 2 sets would be better 1 with vees cut into them. From there bearing splitters are also a must. Then you need what I call furniture, pieces of steel bar and pipe large and small to make up the difference under ram of press. These must be straight and parallel. The next thing you will need is a set of vee blocks and a dial indicator to check straightness. Another set of vee blocks to use under press ram is handy to straighten shafts. A lathe and a mill is great to make your accessories with or a very good friend with a machine shop.
/ Using a shop press - tips & tricks #23
thats a neat idea for height adjustment. saves a lot of drilling for pins.
/ Using a shop press - tips & tricks #24
Plus you'll build up good muscles lifting those bars!
(4) Kinze Gauge Wheels (A65640)
(4) Kinze Gauge...
Bainbridge,Georgia (A65640)
Bainbridge,Georgia...
John Deere 6400 (A64126)
John Deere 6400...
40' Shipping Container (A66285)
40' Shipping...
John Deere 2155 (A62177)
John Deere 2155...
2012 Dodge Ram 1500 4wd (A62679)
2012 Dodge Ram...
