Using a shop press - tips & tricks
   / Using a shop press - tips & tricks #21
   / Using a shop press - tips & tricks #22
I hope I am not speaking out of turn, for pressing bearings the first thing you need is a set of bed or arbor plates long enough to go across your press. these need to be at least 1 inch thick and exactly the same size. they really need to be sized in a mill. 2 sets would be better 1 with vees cut into them. From there bearing splitters are also a must. Then you need what I call furniture, pieces of steel bar and pipe large and small to make up the difference under ram of press. These must be straight and parallel. The next thing you will need is a set of vee blocks and a dial indicator to check straightness. Another set of vee blocks to use under press ram is handy to straighten shafts. A lathe and a mill is great to make your accessories with or a very good friend with a machine shop.
   / Using a shop press - tips & tricks #23
thats a neat idea for height adjustment. saves a lot of drilling for pins.
   / Using a shop press - tips & tricks #24
Plus you'll build up good muscles lifting those bars!
2006 KENWORTH (INOPERABLE)T800 (A55745)
2006 KENWORTH...
Mobile toilet with shower (A53424)
Mobile toilet with...
LOAD OUT INFORMATION (A53084)
LOAD OUT...
2011 FREIGHTLINER CASCADIA (INOPERABLE) (A55745)
2011 FREIGHTLINER...
2014 VOLVO A25G ARTICULATED DUMP TRUCK (A51406)
2014 VOLVO A25G...
2013 Chevrolet Equinox LTZ AWD SUV (A55758)
2013 Chevrolet...
