Rotary Cutter Using a new rotary cutter
   / Using a new rotary cutter
Thanks, FiremanPat.
There isn't a hyperlink to the thread you spoke of. Could you tell me where you found it?
Thanks for all of your help!
Thank you, Greg G.
I will definitely try that out and see how it works. I really appreciate all the help I've gotten so far on this discussion board.
Thanks again!!!
   / Using a new rotary cutter #13
If you only have draft control.. you will need to adjust the lift often. Otherwise i will assume position control.
Hook mower to lower lift arms. lift the lift so thatthe front of the mower is at the height you like to mow at. Mark your 3pt lift quad.. or if it has a set screw, mark it there. Now, adjust tail wheel so that the rear of the mower is just slightly higher than the front of the deck.. probably 1/2 inch or less, per foot of cut.. so ideally about 1.5 inch or so is a good place to try.
Now adjust and attach toplink. Most units have some slack int he toplink connection point, like a "U" shaped piece of metal that will swing a little.. or a slot the pin rides in. these sereve to gine a little play to allow for uneven terain. Adjsut your toplink so that while on level ground, it is int he middle of the range of motion available.
That's a basic but decent setup plan...You should be goood to go for a trial run, and then make and adjustments as needed.
Soundguy
pooters said:
Just purchased a new Bush Hog rotary cutter (42") to go along with my new Kioti CK 20 HST. The field that I mow is uneven terrain and I found that I was constantly adjusting the height of the 3 pt hitch to maintain a relatively even cut. Sometimes the cutter would be too high and other times the front end of the cutter would plow.
Is this normal for uneven terrain or do I not have the cutter mounted/adjusted properly?
Thanks for your help.
Good advice, Soundguy. Thanks!
   / Using a new rotary cutter #16
That got a pretty good snort from me. I like that.. funny..
Soundguy
   / Using a new rotary cutter #17
What you're experiencing is normal. When the rear wheels drop into a slight depression, the cutter will cut shorter. When the rear wheels raise over a slight hump, the cutter will cut taller. Only way to avoid this would be to mount at least one outboard guide wheel onto the cutter body. I've thought about doing this, as I have a very heavy duty castor wheel that's adjustable for height and can even be swung up out of the way. However, it would stick out to one side. I'd have to watch in not going too close on that side to trees and such.
Others talked about using an adjustable slide on your top link. My LX4 cutter has this. It doesn't stop the uneven cutting due to the rear tires going over rises or into dips. Think the only way this would even things out would be to adjust the rear of the cutter to cut lower than the front. This generally isn't recommended because it takes a bit more hp because you're cutting the grass (going forward anyway) several times.
Ralph
I like the idea of mounting adjustable wheels on the sides of the cutter. If I understand you correctly, that would allow the cutter to follow the terrain more naturally. But, it sounds like you would end up towing the cutter rather than carrying it with the 3pt hitch.
   / Using a new rotary cutter #20
Glad to be of service, now fill in your profile and get some pictures posted.
The info in the profile lets everybody know what color your tractor is and what specific implements you have.
Happy Tractoring
2023 54' Hooklift Dumpster 20 Cubic Yard (A53422)
2023 54' Hooklift...
2010 INTERNATIONAL SF637 ROLL OFF TRUCK (A55745)
2010 INTERNATIONAL...
2022 Club Car Tempo Cart (A55853)
2022 Club Car...
WACKER NEUSON LIGHT TOWER (A55745)
WACKER NEUSON...
2018 Toro Workman GTX Electric Utility Cart (A55851)
2018 Toro Workman...
2021 Allmand Bros Maxi-Lite II 20kW S/A Towable Light Tower (A55973)
2021 Allmand Bros...
