Using a linear actuator to control the top link
   / Using a linear actuator to control the top link #11
Thanks guys. I guess it was a stupid idea. I just hate hydraulics but it looks like I better change my attitude about them.
BTW ArlyA, it is a Cat 1 3 pt on a 24HP JD855, and I was planning a getting the Land Pride BB1254 Box Blade and Titan forks
Just curious, why do you "hate" hydraulics?
Also consider the 25 series box blade from Landpride. They are heavier and stronger then the 12 series. Weight is your friend with ground engagement equipment.
   / Using a linear actuator to control the top link #12
Hydraulics are your friend, and are not deserving of your hate. All Hydraulics want to do is to serve you and make your life easier. Perhaps you didn't mean to say hate, and you meant to say "don't understand?" We can help answer questions here. I am also more "electrical" oriented having spend most of my life working with electronics, but I have learned much here and on you-tube about hydraulics. Hydraulics are a wonderful thing, and I believe everyone should learn more about them. Call me Pollyanna if you wish, but more hydraulics, mean a better world :)
   / Using a linear actuator to control the top link #13
Once you figure out the hydraulics terminology and operating concepts, it is a wonderful tool. The initial learning curve at least for me was more like a wall, but once I got over that, no problems. And indeed there are many knowledgeable folk here to lend a hand.
You are correct. I have experience with air and electric but none with hydraulics. I have some learning to do. I will search for threads on installing a top link cylinder. Thanks
   / Using a linear actuator to control the top link #15
I have a Sleeve Hitch with an electric actuator that lifts and lowers a rear implement on my garden tractor. Johnny Products sells it. Not a huge weight capacity--around 350 lbs--but then it's a pretty small actuator. Nice thing is it has down-pressure, which helps since you're using a pretty lightweight implement with it.
Could a bigger one do the job? I have no idea, but agree it would be great if it could.
   / Using a linear actuator to control the top link #16
If you really want to bad enough, you could mod a stock three point turnbuckle with a gear reduction. I bet. Not worth the effort but I bet it could be done.
   / Using a linear actuator to control the top link #17
I have seen a 100 inch cylinder compress rubber into something resembling iron or concrete. I freaking love hydraulics.
New/Unused 20ft Bi-Parting Iron Gate (Elk Design) (A48837)
New/Unused 20ft...
2020 CATERPILLAR 988K WHEEL LOADER (A50458)
2020 CATERPILLAR...
2015 Ford F-150 4x4 Pickup Truck (A48081)
2015 Ford F-150...
2016 Ford Explorer AWD SUV (A48082)
2016 Ford Explorer...
UNUSED LANDHONOR SKID STEER HYD LOG GRAPPLE (A50460)
UNUSED LANDHONOR...
ALL ITEMS NOT PICKED UP IN 30 DAYS WILL BE RESOLD FOR STORAGE!! (A50774)
ALL ITEMS NOT...
