Using a Kubota to Power a Generator for Extended Periods
   / Using a Kubota to Power a Generator for Extended Periods #21
I don't understand why tractors don't have a shut down feature. OR, at least a LOUD signal. I contemplated this today, while using our open station JD during daytime hours. I would probably never see the indicator light for a serious fault, and wouldn't hear the alert, wearing ear protection.
Some do.. apparently green ones don't :) Might want to upgrade. ;)
   / Using a Kubota to Power a Generator for Extended Periods #22
I wish I had time for another such project. Wiring up a relay that is. Has anyone ever bought Murphy stuff? Can you say EXPENSIVE? I try and find what I want on E-Bay. Sometimes it takes a while.
Curious, if anyone actually had a catastrophic tractor failure running a PTO set, or heard of one.
   / Using a Kubota to Power a Generator for Extended Periods #23
And what about if someone tries to steal your rig so their beer cooler doesn't heat up ? And what if you park it on a hill and the machine rolls over when you bump into it at night ? And what if it gets a flat tire and AAA won't change it while its running and your kids are playing with their computer games and can't shut them down ? And what if the sky falls down or a meteor becomes a meteroite right there? What if you are living 'off-grid' and don't remember this when your neighbor's power goes out ? What if its 70 degrees outside, the refrigerators are empty and you have lots of trees around you ? What if your neighbor owns an extension cord manufacturing company ? Just what will you do ? OMG !:confused:
Gosh, I guess I'd just shoot myself except it would probably hurt. Maybe you should check fluids before you start all this effort. Maybe you should own a tractor that doesn't leak, burn or spew it's fluids out and commit it to a house alternator. Perhaps a bicycle powered battery charger is really all you need.
   / Using a Kubota to Power a Generator for Extended Periods #24
It doesn't take a whole lot to wire in a pressure switch with the choice of contacts that open or close when there is no pressure . Same goes for over temp switches .
There is usually some place to tie it into the electrics to either shut down or sound an alarm. I don't know how long it would take to stop a conventional diesel with an electric fuel solenoid between the low pressure pump and the injection pump? Probably less than a minute?
   / Using a Kubota to Power a Generator for Extended Periods #25
   / Using a Kubota to Power a Generator for Extended Periods #27
Dont feel bad, mine won't let me upload a pic of a Murphy gauge setting on my desk... :/
   / Using a Kubota to Power a Generator for Extended Periods #28
I suppose they got called Murphy Gauges on account of anything that can go wrong will. I had a low hour 42 PTO hp Universal tractor that was running my Onan 3ph 15kw rig for a few hours. It was mounted on the 3ph but was lowered to the ground. When I went to leave, I realized the 3ph no longer worked. Sheit happens. I never did get the hitch working reliably again, before we traded it on the JD.
   / Using a Kubota to Power a Generator for Extended Periods #29
I currently have a backup for my backup for my backup, because you just never know, and besides, I'm afraid of the dark!
Main 7.5 KW Onan/Kubota
2nd 3.7 KW Yanmar
3rd 3 KW Alpha (220V) Inverter that plugs into my 48 Volt Gator Batteries.
   / Using a Kubota to Power a Generator for Extended Periods #30
12.5kw pto gen. Is my backup
2010 Volkswagen Jetta Sedan (A48082)
2010 Volkswagen...
Bradco 609 Backhoe Attachment (A48837)
Bradco 609 Backhoe...
2012 WACKER NEUSON G50 MOBILE GENERATOR SET (A50458)
2012 WACKER NEUSON...
377817 (A48836)
377817 (A48836)
NEW HOLLAND TV6070 TRACTOR (A50459)
NEW HOLLAND TV6070...
Pair of Tractor Tires on Rims (A47164)
Pair of Tractor...
