Using a horizontal-vertical log splitter
/ Using a horizontal-vertical log splitter #21
Did you consider the cheaper "Huskee" splitters sold at Tractor Supply?
Yes, I did look at those. I just felt better with the Brave Products splitter. I'm only planning on buying one splitter to last a life time and this splitter has a good record (other then a recall in 2007 for some bad hydro cylinders :eek: ).
Once I start working it I'll post a review.
/ Using a horizontal-vertical log splitter #22
Has anybody used/does anybody own one of the Troy Bilt splitters available at Lowe's? (I know, Troy Bilt is now owned by MTD which makes alot of crap!).
Lowe's has a Troy Bilt splitter that can be used both horizontal or verticle. 33 ton splitting force with a Honda 270cc (9 hp?) GX engine. It looks somewhat well made and costs around $2100 I think. 12 second cycle time I believe.
Lowe's also sells a smaller Troy Bilt splitter for about $1600 (27 ton, B&S 5.5 hp, also horizontal/verticle combo.) I'm kind of guessing from memory on the smaller sized one's specs!
I've got a Troy Bilt 27 ton w/Honda engine. (160cc) I got it at Lowes. Paid $1389. I'm pleased with it. In fact, I just walked in the house after spending the day using it. It cycles fast enough to keep pace with me over a long day.
/ Using a horizontal-vertical log splitter #23
I was looking for a splitter 3 years ago to run off my tractor. I did not like any of the 3 point models I saw so I built my own. Here are my thoughts.
I did not like most 3 point units because they went right to left across the back. That only left one side of the splitter open to work from so I made mine to stick out the back. We usually split with 2 guys, one running it and one bringing over the logs.
I wanted the wedge to be on the ram and put the foot on the beam. I welded 3/8" steel cleats and have never had a log slip off. I also made a plate that can be inserted instead of the wedge so I can use it as a shop press. Real handy.
I wanted horizontal and vertical ability.
Here are some pics. I have about $425 in it and did all the fab work myself, tacked it up, ect. All the welding that if it broke I could get hurt I left to a professional welder. Cost me a case of Bud Light.
Chris
2016 CHEVROLET TAHOE (A66091)
2016 CHEVROLET...
2012 PETERBILT 388 (A67714)
2012 PETERBILT 388...
2001 MACK VISION DUMP TRUCK (INOPERABLE) (A67714)
2001 MACK VISION...
2012 Volkswagen Passat (A66738)
2012 Volkswagen...
Unused 2023 Monroe-Tufline DS1120T 10ft. Hydraulic Box Scraper Tractor Attachment (A66734)
Unused 2023...
2013 CHEVROLET CAPRICE POLICE CAR (A66091)
2013 CHEVROLET...
