Snow Using a FEL to plow snow?
   / Using a FEL to plow snow? #12
Duane-I used the FEL on my B7500 for my first time to remove snow today and it worked just fine. I don't have a rear blade and can't afford to go out and get a plow. It was a powdery snow and we only had 6"so I guess that made it somewhat easier. It takes some experimenting to get the right angle on the bucket but, once you get the hang of it it works real well. I have a 350' asphalt drive which took me about 21/2 hours and as far as I could tell I didn't do any damage to the surface.
   / Using a FEL to plow snow? #13
<font color=blue>I have a 350' asphalt drive which took me about 21/2 hours and as far as I could tell I didn't do any damage to the surface</font color=blue>
RFischer & Duane, I have a U shaped gravel driveway, total straight length is maybe 200-250 feet. It took me 20 minutes to plow 4" with my rear blade.
Don't know how much snow you get in kentucky, but seems like the blade saves some time.
Being in New England, This is the third plowable snow we've had this year. I bought a used front plow & am going to build a bracket to attach it to the front of the tractor so I don't have to keep driving backwards.
   / Using a FEL to plow snow? #14
Hazmat,
This is a Really Simple design for mounting a regular type plow into the bucket of a tractor. 2 pins, 1 chain and your hydrolic hose if so equiped and it's either on or off and then you still have your bucket attached for snow banks etc.
I am posative that anybody who can weld (I can't) could thow this bracket together in no time.
   / Using a FEL to plow snow? #17
Picture 4
This is the way I will eventually attach mine when I stop procrastinating.
   / Using a FEL to plow snow? #18
Mark,
Indeed I like your design /w3tcompact/icons/smile.gif and looks like I'll be getting my crayons out for next year plan. /w3tcompact/icons/wink.gif
   / Using a FEL to plow snow? #19
Is that a rubber cutting edge?
   / Using a FEL to plow snow? #20
Steven,
In answer to your ? <font color=blue>Is that a rubber cutting edge? </font color=blue>
Nope, that was / is a good old fashion bolt on steel cutting edge.
2014 Ford Taurus Sedan (A56859)
2014 Ford Taurus...
2023 Unverferth 3PT 6 - FT Perfecta Field Cultivator (A55315)
2023 Unverferth...
2017 Ford Escape AWD SUV (A55758)
2017 Ford Escape...
2016 CATERPILLAR 325FL CR EXCAVATOR (A52705)
2016 CATERPILLAR...
2018 HINO CONVENTIONAL TYPE TRUCK (A58214)
2018 HINO...
DEUTZ MARATHON 60KW GENERATOR (A55745)
DEUTZ MARATHON...
