Using a Brush Hog on BX2200
   / Using a Brush Hog on BX2200 #11
I have a taylor way 4' brush mower. My Bx handles that thing well. I have had the tractor and mower for about 1 year now and have mowed about 20 acres total with it. I leave the loader on for ballast, and also to " find" hidden objects in tall grass and weeds. I lower the bucket with it rolled back about 6" off the ground. Fire ant mounds roots and stumps can be detected real quick.
   / Using a Brush Hog on BX2200 #12
I have a 4 ft King Kutter on my BX2200. Used it this week to cut deep grass and light brush for 8-12 hours at my x-mas tree farm. It worked much better than I anticipated. I used to have problems with my other old gas tractors(Ford NAA and Ferguson TE 20) bogging down with a 5 ft Howse. By the books they have more torque than the BX. Must be the 4 ft vs. 5 ft hog and/or the fact that the little BX weighs far less and therefore uses less of the available power just to turn the wheels to move the tractor forward.....
   / Using a Brush Hog on BX2200 #13
I'm sure the reduction in cut by 1 foot plays a big part, but remember, not all cutters, even of the same size, use your engines power the same way. The gearbox, blade design, deck design, and even the way the blades mount all make a difference.
As an example. Take 2 blade designs. Let's say they're identical with the exception of where the offset from the blade mount down to the cutting edge is located. Blade "A" offsets the blade downward immediately after clearing the blade holder. Blade "B" stays level all the way out until just before the cutting edge. If you go to your local supplier (TSC, Rural King, etc.) you can find both types. Blade "A" will have a long unsharpened section level with the cutting edge. Blade "B" will have the same length, but all the unsharpened part will be at the blade holder level. Everything at the cutting edge level is sharpened. Which takes more HP to run? Blade "A" comes into contact with the grass, brush and other material with not only the cutting edge, but also the unsharpened section. Blade "B" only has the cutting edge in contact with material, (unless of course you climb on top of that big rock or stump /w3tcompact/icons/smile.gif).
Most 4' cutters have blades so short that they fall into the Blade "B" category. When you get into larger 5' and 6' cutters you really notice the difference. This factor, in addition to the blade flex factor is why many upper crust manufacturers use shorter blades and larger blade holders on their bigger cutters.
This is a long way of saying that not all cutters are equal. Just because your neighbors Brand X cutter bogs your machine down, doesn't mean Brand Y of the same size, will.
2015 Peterbilt 348 Dump Truck (A55973)
2015 Peterbilt 348...
2011 INTERNATIONAL WORKSTAR 7400 SBA 6X4 DUMP TRK (A52706)
2011 INTERNATIONAL...
2015 UTILITY 48FT REEFER TRAILER (A59575)
2015 UTILITY 48FT...
1987 CATERPILLAR D6H HIGH TRACK CRAWLER DOZER (A52709)
1987 CATERPILLAR...
Filabot Spooler (A56860)
Filabot Spooler...
Misc Pallet of Winch, Tools, and Driveshaft (A57454)
Misc Pallet of...
