using 4 wheel drive
/ using 4 wheel drive #21
Re:beenthere
Mark, I think it may be the first time I've even heard "keep the greasy side down"; I've just always heard "keep the shiny side up."/w3tcompact/icons/wink.gif
/ using 4 wheel drive #22
Re:beenthere
I worked for years in the truck repair industry. We always said that to the drivers. If you ever looked at a detroit disel bottom side you would sure know which was shiney and which was greasey. We always said if it wasn't leaking oil it was out of oil. JIM
/ using 4 wheel drive #23
Re:beenthere
Bird,
You must be one of those "glass is half-full" kind of guys /w3tcompact/icons/smile.gif.
TresCrows,
Your "dryly amusing" post forced a guffaw out of me at work - I've drawn some strange looks.
/ using 4 wheel drive #24
Re:beenthere
Bird - <font color=blue>I've just always heard "keep the shiny side up."</font color=blue>
I've heard that! I never knew it had anything to do with that. Of course, since there's been so few times I've ever driven anything that had a shiny side, I've got an excuse. /w3tcompact/icons/laugh.gif
/ using 4 wheel drive #25
Re:beenthere
Along the same thread, one that I've heard (and used) is to "keep the rollers on the bottom".
Seems they all have the same general intent: there is a proper operating attitude for most equipment, be it tractors, cars, trucks, airplanes, etc... As for greasy side down, some are greasier than others. /w3tcompact/icons/smile.gif
Unless it's British. We all know that electronic equipment operates on smoke. I've noticed that British electronics needs a lot more smoke than electronics from other places /w3tcompact/icons/laugh.gif....
Now I'm getting out of here before the stuff starts flying. /w3tcompact/icons/shocked.gif
/ using 4 wheel drive #27
Re:beenthere
<font color=blue>keep the rollers on the bottom</font color=blue>
Or "Keep the rubber on the road."
/ using 4 wheel drive #28
Re:beenthere
<font color=blue>Were you refering to " The King Of Darkness "</font color=blue>
I believe that's one alias. Another was "Lucas Flash and Flicker". /w3tcompact/icons/laugh.gif
it would seem that the main topic somehow got sidetracked.
anybody know how this happened?
accordionman
william l. brown
/ using 4 wheel drive #31
it would seem that the main topic somehow got sidetracked. anybody know how this happened?
it would seem so. It's sometimes a common affliction around here.
Getting back on the topic.... I find myself switching in/out of 4WD quite often. Particularly when I'm working on the road. I need 4WD to pull a full boxblade, or when doing serious ground engagement. However, if I want to turn on a dime, or want to avoid tearing up the driveway, I find it works better to be in 2WD. So I'm constantly "rowing the boat" with that 4WD lever. Others doing the same thing? Or is this an "as the job demands" kind of thing????
/ using 4 wheel drive #32
I usually put either 'bota in 4WD for all jobs other than mowing or pulling my harrow. I do not worry about "hard surfaces" such as hard packed dirt, gravel etc. I do not use 4WD on concrete, blacktop etc unless just a short distance to cross.
I figure it was meant to be used so I use it, besides, without it the 'botas are nothing more than power wheelbarrows, with it they are dirt eating machines.
J
/ using 4 wheel drive #33
accordionman,
I know I'm not saying anything new, but, I have a Jeep with FWD. The owners manual says don't use FWD on dry pavement. The same idea holds with tractors.
Buck
/ using 4 wheel drive #34
THATS PRETTY MUCH THE WAY I WORK IT. ONLY IN 2 WD ON DRY PAVEMENT OR HIGHER SPEEPS.
/ using 4 wheel drive #35
AC-man, I am with GlueGuy, here I am normallly not in 4WD unless needed. I have a lot further to go to use my tractor most of the time than most so I do not use 4 while traveling, only while using ground engageing equipment and FEL... Will take it out of FWD while turning if I am on the lawn or out in one of the crop or hay fields...
Here is a very brief view of 4WD and hard surfaces... It is really about TRACTION.... When turning the front wheels while in 4WD the wheels try to turn at the same rate, (no they do roll at the same rate). Since the inside wheel has a shorter arc to turn than the outside wheel the difference has to go some where.. In other words one tire or the other has to slip. In solf dirt and a tight turn you really plow up some ruts. If both wheels have plenty or traction (hard dry surface) the the gears in the 4WD train forces the tire to over come the large anount of traction the tire has. This causes great stress on the gears and u-joints in the front drive. Leading to ware and broken drive line parts. How often do you want to put the front end under extreme loading, every time you turn the wheel on a hard surface.....
Using 4WD while plowing snow even on pavement there is an enough lubricant (called wet pavement, snow and ice) to allow the tires to slip plenty and should not over stress the drive line.
Hope the quick, simple answer helps....
/ using 4 wheel drive #36
<font color=blue>...I am normallly not in 4WD unless needed.</font color=blue>
I like to keep mine in 2WD unless I really need the extra traction. It's for the same reason that I keep my brake pedals locked together unless I really need to use the brake turning.
I like to minimize the chances of forgetting some day and being in the wrong mode while driving on the highway.
Besides, if you always use 4WD then you'll never know if you wasted the money you spent on it. If you can't make it through in 2WD, then you know you made a good investment as you pull up that 4WD lever. /w3tcompact/icons/grin.gif
/ using 4 wheel drive #37
I always use 4x4 drive when going up or down grass, snow or ice. Going up it keeps you moving and going down it helps to slow and stop free wheeling.
Of course 4x4 is also needed when using some attachments that require the extra traction.
Otherwise, I keep in 2 wheel drive so as not to create unnecessary wear on the font gear box.
/ using 4 wheel drive #38
<font color=blue>...Here is a very brief view of 4WD and hard surfaces... It is really about TRACTION.... When turning the front wheels while in 4WD the wheels try to turn at the same rate, (no they do roll at the same rate). Since the inside wheel has a shorter arc to turn than the outside wheel the difference has to go some where.. In other words one tire or the other has to slip.</font color=blue>
Is that really the issue? I thought only one front wheel drove? I would think the issue would be more the difference between the driving front wheel and the rear wheels? But I'm a newbie... /w3tcompact/icons/smile.gif
/ using 4 wheel drive #39
Bob, it's true that in mud/snow/ice you may only have one wheel turning due to the differential but on a hard, dry surface both will try to turn (or neither will slip). That's where the problems can occur in 4wd as the front driveshaft and rear may need to turn at different speeds while steering.
I don't think I explained this very well, but it's been a heck of a week. I'm going for beer, then hockey. Anyone want to join me /w3tcompact/icons/smile.gif
/ using 4 wheel drive #40
Rob,
<font color=blue>...Bob, it's true that in mud/snow/ice you may only have one wheel turning due to the differential but on a hard, dry surface both will try to turn (or neither will slip).</font color=blue>
Ahah.. I didn't know that. I thought it was just one wheel on the front. Thanks for the info!
<font color=blue>...I don't think I explained this very well, but it's been a heck of a week. I'm going for beer, then hockey. Anyone want to join me /w3tcompact/icons/smile.gif</font color=blue>
You explained it just fine, and yes, I'll meet you in 20 minutes for the beer! /w3tcompact/icons/smile.gif
Thanks,
Bob
2013 WINSTON AP22024AL-DC EQUIPMENT TRAILER (A66091)
2013 WINSTON...
2019 FREIGHTLINER M2 4X2 S/A NON 26FT NON CDL BOX TRUCK (A67148)
2019 FREIGHTLINER...
2018 Blue Bird All American/All Canadian Bus (A64556)
2018 Blue Bird All...
2023 JCB S3246E ELECTIC SCISSOR LIFT (A63276)
2023 JCB S3246E...
2019 JOHN DEERE 325G SKID STEER (A65053)
2019 JOHN DEERE...
USA KB057-48" HYD BRUSH CUTTER (A65053)
USA KB057-48" HYD...
