uses for a front end loader
/ uses for a front end loader #62
I re-roofed my house using my Fel to place the materials on the roof. Having my son operate the tractor, I also painted the trim of my house. Essentially a mobile scaffold. I haul firewood, tow my splitter, trailer, dig, use it as a lift to trim lower to mid branches on trees. Without the Fel, I would have half a tractor...
/ uses for a front end loader #63
Would not need the tractor without the FEL. Us it for feeding the burn pile. Moving wood and brush. Carrying the mower deck. Snow, dirt, rock.
/ uses for a front end loader #64
You can use it to install / remove a building extension.
/ uses for a front end loader #65
Couple of years ago, we used ours to haul water from one of our ponds to extinguish a field fire.
/ uses for a front end loader #66
You guys pretty much have touched on everything that I have used my FEL for. Thanks for some interesting posts.
/ uses for a front end loader #67
Unload the new to me TORO Groundsmaster.
/ uses for a front end loader #68
Putting in a 16x7 pipe cattle guard.
/ uses for a front end loader #69
Used my FEL to put up and brace a ladder on the roof (45 degree pitch is a PITA to work on otherwise) while I went up it to clean the chimney.
Also used it to unload my lathe from the back of a truck and move it into the building.
/ uses for a front end loader #70
Used the FEL and the ROPS to hold the scaffold plank for repair of facia board.
/ uses for a front end loader #71
Another use was to set four 16' 6x6 treated poles in dug holes when working alone.
First tested out some rigging using a short post. Then as it appeared to work well, strapped down the 16' at a height that allowed room under the tractor for the butt end and also distance up to be able to set the pole in the hole. Worked well, without a hitch.
2021 Weber CF 2-IIHD Plate Compactor (A61572)
2021 Weber CF...
Baby Goat Decorative Statue (A66738)
Baby Goat...
CAT 988B Final Drive (A68134)
CAT 988B Final...
2021 Mercedes-Benz Sprinter 4500 Modified Food Catering Van (A61573)
2021 Mercedes-Benz...
2003 Toro Workman 2110 Gas Utility Cart (A66734)
2003 Toro Workman...
2019 INTERNATIONAL 7400 SBA 6X4 DUMP TRUCK (A63276)
2019 INTERNATIONAL...
