Backhoe Uses for a Backhoe
   / Uses for a Backhoe #31
one of the handiest things I use my hoe for is moving big brush piles , I raise it up extend straight and back up to the pile then scoop it up and pin it against the mast .
   / Uses for a Backhoe #32
I have a 3pt BH and can take it off in about 10 minutes and on in about 15 minutes. Took a few practice runs to get down to that but it isn't bad.
Mine doesn't get used a lot but is the best thing when you need one. Some of the neighbours help me find jobs for it too, good to have a few favours out there for the times you might need a hand with something.
As for the original question, I bought mine to dig around the foundation to install weeping tile to correct a moisture problem and install insulation because you might as well while the fondation is exposed. Since then I have removed rocks, stumps, dug in a few drain lines and trenched in the electrical service for a new neighbour.
   / Uses for a Backhoe #33
I've had 5 backhoes on the last 5 tractors I have had. I also have a 44,000 lb excavator. I would never be without a backhoe or excavator as I use it all the time even just to soften the ground. When I read all the posts about digging with a FEL and using tooth bar to make it dig better, all I can think is you have no idea how well the right tool (a backhoe) can dig. I now have one tractor with a backhoe and loader and one with a loader for 3 pt hitch attachments. sure does make the changeover easier.
Andy
   / Uses for a Backhoe #34
Andy
44K excavator! - you're making me sick :D
Absolutely agree with you.
Also like to second or third the idea others have mentioned, CUT with a backhoe doesn't really have the scale or reach to do things well that are very far from the rear of the tractor. I have had to dig dirt, put it in a pile, then move the tractor and shift the pile another 8'-10' because I couldn't get at with the FEL.
I have also noted mine barely straddles it's own trench. I have my wheels set standard narrow to fit between various obstacles.
They are handy for close in, light work and I am glad I have one. But I don't kid myself about it being a real digging machine.
Dave.
   / Uses for a Backhoe #35
I bought my first tractor (new) just a year ago. I was thinking about a backhoe, but finances at the time (I'd just retired), well...
I found that the FEL didn't work worth poop in digging stumps (and I live on five acres of an old eucalyptus orchard?/plantation? with wall-to-wall trees & stumps). Recognizing that the economy was in the toilet, I figured that older, used machines would be on the market as contractors/landscapers/etc contracted and sold their old equipment. Six months ago I found a 40 yr old industrial machine (Massey Ferguson 3165 w/<1800 hrs) on the market really cheap (much less that just a bolt-on backhoe). I had to sink a couple dollars into it, but still less than the new backhoe and I now have a second tractor. If, when I'm done digging stumps, I think I no longer have a need for it I can sell it for at least most of what I have into it. With the two machines, it takes me zero minutes to prepare the backhoe.
   / Uses for a Backhoe #37
I'm with Guywire. Step off JD tractor. Step on Case backhoe, start engine, Dig...
I read about spending $8K-$10K for an add on backhoe when one can buy a full size
rig for $10k-$12K and have the weight, power, reach, and speed of a full size machine.
Granted, a homestead on a few acres probably doesn't need a full size but, when
heavy work needs to be done a heavy machine is needed.
   / Uses for a Backhoe #38
I know a guy that told me a long, long time ago, it's ok to rent or barrow a tool once. If you need it more than once, then you need that tool, buy it if you can any way afford it. I have used that bit of advice for the last 30 some years. :D ;)
   / Uses for a Backhoe #39
One problem that makes me shy away from buying old equipment is I have no idea how to evaluate what the real condition of a machine is due to no experience. I would hate to buy something that looked okay to me and seemed to function correctly, only to find out it really needs some multi-thousand $ fix.
Dave.
   / Uses for a Backhoe #40
Dave.
This does become a problem. If you don't know yourself and or don't know anybody that you can trust, then purchasing used equipment takes on a new perspective. I would have to say that that would limit me to a dealer that would have some sort of warranty on their used equipment.
2014 Chevrolet Impala Sedan (A56859)
2014 Chevrolet...
2019 CATERPILLAR 740GC OFF ROAD DUMP TRUCK (A52707)
2019 CATERPILLAR...
2009 Ford Ranger Pickup Truck (A55852)
2009 Ford Ranger...
2015 BOBCAT T550 SKID STEER (A52707)
2015 BOBCAT T550...
2006 FREIGHTLINER CL120 DAY CAB (A53426)
2006 FREIGHTLINER...
23311 (A51694)
23311 (A51694)
