useful toy
/ useful toy #21
Just my 2 cents worth.. Metal fatigue can be a big factor. Bolts shearing off. That blade breaking and bouncing off of something and getting you anyhow.. Safety glasses won't do much for half of the blade spinning at you. It does look fun. Not fun enough for me to use like that though. Good luck.
/ useful toy
work is a balancing act between safty and getting something done
it was made to do a particular job that has to be done once a year for a few hours, and with running it far below its design limits and only having used it 3 times fatigue isnt much of a factor yet
its held on by 2 halfinch bolts with nylok nuts and as i take the blade off each time to store it and replace the nuts i get a chance to check it out
and yes in critical aplications i use lock nuts just once, harkens back to my military days as an aircraft mechanics and regulations concerning self locking nuts
im rather careful in what i do i was a tool and die maker for 30 years and was never seriously hurt and have all my fingers
its not like there are stones in the vegitation 8 feet in the air
/ useful toy #24
IMO, nicely fabricated tool. How much did you spend to build it? What else have you been building that might interest us?
/ useful toy
ive made a set of forks, a scarafier for the 3 point and my crowning piece is my stone picker
a universal attachment to mout various attachments to my fel
and a grader that worked out better than i hoped it would
/ useful toy #26
Ok Chickenman it sounds like you are doing the right preventive maintenance. The picture sort of look liked it might have been an old beast. My mistake.
/ useful toy #27
chickenman said:
im using a comercial grass blade that spins upwards of 15,000 plus rpm im going a fraction of that and the vbelt will slip and it will stop spinning long before i reach any limit it may have
What kind of commercial mower spins the blades at 15,000 RPM? As far as I know, most if not all commercial mowers limit the tip speed of the blades to under 18,000 feet per minute.
What is the diameter of that blade?
/ useful toy #28
Well said.
I've never seen a useful tool that couldn't hurt you.
Did you know that wasp stings kill more people than mowing machines? That's right, you better park it, or wear a wasp-proof suit. :eek:
In all seriousness, everyone has their own built in scare-O-meter, and each one is set a little differently according to their experience. Noisy, spinning equipment understandably scares a lot of people that have never been around it. You've obviously designed and built enough equipment that your meter is well calibrated. Enjoy your cool tool!
/ useful toy
i belive your right my memery seems to have been faulty as to rpm/sfm
so as it stands im running it at about its rated speed or below
/ useful toy
have_blue said:
Well said.
years ago i was sitting at my bench doing some layout work with a salvaged unshrouded refridgeration fan blowing on me, at this particular time a state osha inspecter stopped and said i couldnt use that fan so i reached out and stuck my fingers into the spinning blade and it came to an imediate stop, he kinda looked at me funny and walked on
/ useful toy #31
Sometimes common sense rules, but it's getting more and more scarce. OSHA will allow you to use a 10,000deg plasma torch, but won't trust you with an air hose. It's amazing we can produce anything these days.
PORTA POTTY (A68842)
CAT 930 Coupler (A68134)
CAT 930 Coupler...
2014 MAC FLAMELESS HEATER TRAILER (INOPERABLE) (A67714)
2014 MAC FLAMELESS...
RANGER S/A TRAILER W/WELDER (A67714)
RANGER S/A TRAILER...
Ford 340B Loader Attachment
Ford 340B Loader...
2014 PETERBILT 579 MID-ROOF SLEEPER (A67714)
2014 PETERBILT 579...
