useful toy
/ useful toy #1
chickenman
can be mounted to cut horizontaly or vertically
/ useful toy #2
That reminds me of some of the wood splitters I have seen on U-tube. Bubba says watch this .... while T-Bone says y'all be careful now.
/ useful toy #3
At first glance, I thought it was a woodsplitter. Then I saw the blade. You'd have to be out of your mind to use that thing...
/ useful toy
how fast, dont really know but it works
and ive been whacked many times its not as hard as it looks like it would be
i wear safty glasses and a hat and it cuts in both directions so i use a rotation that flings most away from me
actually i find the ticks and heat more annoying
if needed i could add a wire shield in front of me
/ useful toy
DreaminGreen said:
I sure could use something like that, but with a circular saw blade on it.
ive cut up to 2"-3" branches and saplings with it by just easing into them
/ useful toy #9
Hope you never have anything walk up to you while working it ...kids, dogs, people etc.
I'd seriously consider some kind of shroud.
Other than being dangerous out of this world, it looks like a cool dangerous tool.:)
/ useful toy
so far i only use it out back on my horse track to trim back vegitation and trees when no one is around
if i was to use it otherwise i'd shield it, it would be easy to do
with safty glasses and hat there is little danger to the operator as the cutter is some distance away
iv used it 3 times for about 2 days each time with no ill affect
its one of those things that looks more dangerous than it is
i was a tool and die maker for 30 years and in a shop some of the machines that look the most dangerous are in fact the safest, sorta like with this
the way i use it its harmless to me, other aplications maybe would be different and i would use it acordingly
iv never gotten so much as a bruise
anything that has hit me is more a thud than anything else, a screen could be mounted to the fel uprights if needed
/ useful toy #11
Oh....branches!!!
I thought I'd build one come butchering time....and I was really hoping to get ideas for a plucker too.
/ useful toy
branches sorta just drop down, to big to fly
ive cut through branches up to 2' - 3" , takes careful moving but branches are les hazardous than the smaller stuff
unless youve seen the way i use it , it does look dangerous and under other circumstances might be
im no more willing to hurt myself than the next guy
it may spin maybe 2000 - 3000 rpm , not sure and its far enough away that momentum is lost by the time anything reaches me
/ useful toy #13
Been a medic for many years and seen many accidents with well engineered devices WITH safety mechanisms. I wouldn't be proud of this at all. Hope you have good insurance!
/ useful toy #15
I would want some shroud around that blade in the event that the blade broke. A shroud may not stop a broken blade but it would sure slow it down.:D
/ useful toy
the blade is a comercial cutter blade about a 1/4" by 3" by 24" turning at about 20% its rated speed
when i run into heavy cutting the v belt slips long before enough torque is put on it to break
also it hangs over the fel by about 2 feet so the plane of spin is about 4 feet from me
and up in the air where it cuts theres nothing to break it
and when i flip it to cut horizontaly, id be more worried about the front tire as im sitting well above its plane of spin and have the fel arm and tractor as a shield
you really need to see how its applied to understand
im more likely to be injured driving than useing this the way i do
/ useful toy #17
Are you sure yours spins at 2000-3000 rpm! That doesnt sound right to me. I'd back off that pump of yours if I were you.
The ones I've seen spin real slow. I see these in action regularly and they are a lot less dangerous to the operator than say, a flail mower. The saw blade only rotates at about 40-60 rpm and only produces saw dust which falls down along with the branches it cuts. Where as a flail mower has high rpm and flings stuff far greater distances. A lot of the farmers around me use these to great effect.
They just looks dangerous. Obviously no one goes near the blade when it spinning and the operator is 6-8 ft from it in the seat.
That big circular blade makes a helluva ringing noise as it cuts through the branches...
heres a big one with 4 blades mounted on a long extending arm.
/ useful toy #18
That thing scares me just looking at it. I wouldn't go near it.
/ useful toy #19
Chickenman:
Seems to me you have considered the issues and decided that the gain is worth the risk. Others might decide differently, but that is a personal decision.
Thanks for sharing your work.
/ useful toy
those look like saw blades, im using a comercial grass blade that spins upwards of 15,000 plus rpm im going a fraction of that and the vbelt will slip and it will stop spinning long before i reach any limit it may have
i have quite a safty factor the way i use it
i wear glasses and a hat
ive been hit many times and mostly its anoying
many times when operating a machine tool id have to stand there getting burned by hot chips because i had to, so i could stop a cut, sometimes you gotta do what has to be done
come on if you drive a tractor, your supposed to be macho, dumb and tough
2006 Ford F-350 12ft. Flatbed Truck (A61573)
2006 Ford F-350...
Homemade 6'x15' Trailer (A64912)
Homemade 6'x15'...
2018 INTERNATIONAL DURASTAR 4300 BOX TRUCK (A67714)
2018 INTERNATIONAL...
Unused 2022 Loftness 14CFISV3 Auxiliary Hydraulic Oil Cooler Skid Steer Attachment (A66734)
Unused 2022...
2012 CHEVROLET IMPALA CAR (A66091)
2012 CHEVROLET...
2024 CATERPILLAR 265 SKID STEER (A65056)
2024 CATERPILLAR...
