Tiller USED TILLER QUESTIONS
/ USED TILLER QUESTIONS #1
kbm3
Frankfort, NY (upstate)
NH T1520
Just saw a used 51" Howard Rotovator at my dealer.......this thing is MINT, as the paint isn't even worn off the tines! Is 995.00 a good price for this, and also I would love to hear from anyone who has, or knows about this unit. Thanks!
/ USED TILLER QUESTIONS #2
</font><font color="blue" class="small">( Is 995.00 a good price for this )</font>
In my opinion, Yes.
/ USED TILLER QUESTIONS #4
I would say that is a pretty good $. I paid about $650 for a used 53" Yanmar that was in really good shape, but not anywhere near mint. I looked around for quite a while, including auctions, and that was as good a $ as I could find. As another comparison, the last auction I went to had a 60" KK was about the same condition as the one you're describing and IIRC it went for about $1000. Remember that KK was only about $1300-1400 new. From what I've seen Howards are considerably more $ and have a much better reputation. I've seen several really old Howards still in use.
/ USED TILLER QUESTIONS #5
HOWARD & KUHN rotovators are KINGS between tillers.
So, If you don't want it, send it to me, even it's too small for my needs /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
BTW, I'm looking for something about 80-85".
/ USED TILLER QUESTIONS #6
I used mine on Sunday and am quite pleased with the results. I bought a Howard HR8-1M40 used that needed work. They have a web site at Howard USA and if you go there, Mine is = to the HR7HD that is current production. Tills a strip that is 55" wide. It only cost $100 but had a bent rotating unit and needed bearings and a seal. Tines were about 70%. Removed the rotating unit that is pipe, streightned and pressed in a solid steel shaft that I turned on a lathe to fit the inside dia. of the pipe.
( it took 18 tons of pressure to install the shaft in the pipe, don't have to worry about it coming out. ) It will never bend again!!! Bearings and the seal cost less than $30. Everything else is in good shape. You can still get a manual for them for about $11. If the model you are looking at has a slip clutch, make sure it is adjusted to the specs in the manual. I think the damage done to mine was due to someone adjusting the clutch to tight and getting cought in a tree stump or something like that. The manual gives instructions and a parts list and parts can be ordered from most dealers. I have a Yanmar YM 3000 tractor that has 33 hp, with the tiller on running at full depth ( 6.6") the tractor didn't know it was there, no strain at all. I'd say that at a $1000 it would be a good deal if it is in the condition you describe. Durring my test last weekend I did 2 passes about 400' long in less than 5 min. The rear gate on them can be adjusted up above the soil to leave small groves for watering or with the gate in the rear down it will leave a smooth finish. Think you will like it, sure it is worth the money, /forums/images/graemlins/smile.gif
Chris
2009 Blue Bird All American/ All Canadian School Bus (A61568)
2009 Blue Bird All...
2023 Kubota SVL97-2 Compact Track Loader (A63689)
2023 Kubota...
2003 International 4300 Flatbed Dump 571557 (A62613)
2003 International...
2006 John Deere 250D 25 Ton Articulated Dump Truck (A59228)
2006 John Deere...
Towable Pipe Road Crossing Trailer (A63689)
Towable Pipe Road...
2008 PETERBILT 365 (A65643)
2008 PETERBILT 365...
