Used Kubota B7800
   / Used Kubota B7800 #1
mitchash
Greene, NY
Mahindra MAX 28XL, Jinma 254 (Sold)
I found a used B7800HSD with loader, backhoe, cab, and snowblower. Just over 1000 hrs. looks in decent shape, has turf tires in the rear and industrial tires in the front. They are asking $17,000. for the whole package. Are there any issues with this model that I should know about? Is that a fair price for it? Will it run my 5' brush hog? What should I look for on the tractor?
   / Used Kubota B7800 #2
I have used a B7800 HST with a BH.Capable machine for its size.Would need a little more detail on the make of the back-hoe,cab,loader and blower.It will run a 5ft.bush-hog as long as its not too heavy going.How is the general condition?Paint faded,leaks,dings ect.
   / Used Kubota B7800
The backhoe is Kubota with quick frame mount and the loader is Kubota. The cab is aftermarket I think it's Curtis. It has a few dings and dents but not bad.
   / Used Kubota B7800 #5
I would guess that tractor with the FEL&BH sold for about $17,000 new.So you are gaining a snow-blower($2000+-) and a Curtis Cab($1500+-) with 1,000hrs. I would offer $15,000.My only concern is the two different styles of tires.
   / Used Kubota B7800
It has a heated Curtis cab and a BH75 backhoe. I can't find any specs on the loader and backhoe. How much will the loader will lift?
   / Used Kubota B7800 #7
If it has a Kubota loader;the number(I.E.513) x 2 is roughly the capacity in pounds.513x2=1016lbs.
   / Used Kubota B7800 #8
I did not know that!!!! Is that true for all models??
   / Used Kubota B7800 #9
think it's actually 2.2 times the first 2 numbers. the third being the revision. B7800 should have a 402 loader so 880#. I would guess more like 23000 new. I have a b2910 with loader and trencher that cost 24000. Substitute backhoe for trencher and b7800 was a little less than 2910.
   / Used Kubota B7800 #10
Think 2.2 lbs as in a Kilogram weighs 2.2 lbs. Remember it is approximate. but yes pretty close.
1995 BEALL TRAILER FUEL TRANSPORT PUP TRAILER (A52472)
1995 BEALL TRAILER...
2010 PETERBILT 340 (A52472)
2010 PETERBILT 340...
2022 CASE 580 SUPER N BACKHOE (A51246)
2022 CASE 580...
CATERPILLAR 308E2 CR EXCAVATOR (A50458)
CATERPILLAR 308E2...
2015 HINO CONVENTIONAL TYPE TRUCK (A52472)
2015 HINO...
27ft x 24ft Metal Building (A51573)
27ft x 24ft Metal...
