Used F3060 issues
   / Used F3060 issues #1
Rovcketman357
Shoemkersville,PA
F3060, L3600 GST
Just bought a used 2002 F3060 with 72 mower and GCF-30H grass catcher with 2400 hours.
1. "Idle" is awfully fast - guessing 1500 RPM-ish and nuts at linkage would seem to indicate it is as set at the factory - no wrench marks on paint. Is that normal?
2. Lift seems to be erratic - sometimes normal and other times does not want to lift. Lever does not self center to neutral position- I wonder if that has caused a problem? Otherwise hydraulics seem fine.
3. I cannot find the grease point for "HST Neutral Shaft" from the pathetic illustration in the owners manual. Any help? [I think I have attached the page referenced.]
  • Kubota F3560 Owners Manual 40.pdf
   / Used F3060 issues #2
Don't think there is one. At least not on mine which is the newer model.
   / Used F3060 issues #3
I used to have a F3060....It idled quite fast...think they set it high to prevent engine stall when engaging the mower..Never an issue with the lifting. Had about 2800hrs when I traded it.
   / Used F3060 issues #4
Did you ever figure out what was wrong with the lift? I rebuilt mine but it seems to also work erratically and my mower drops on it own.
   / Used F3060 issues #5
I just replaced my throttle cable on my 3680 (very similar to 3060) and thought it was easy to custom tailor idle.
2021 Cat 289D3 Skidloader (RIDE AND DRIVE) (A50774)
2021 Cat 289D3...
2014 Ford F-150 XL Ext. Cab Pickup Truck (A50323)
2014 Ford F-150 XL...
STORAGE FEES (A52576)
Vermeer 554XL Round Baler (A50774)
Vermeer 554XL...
2018 Allmand Light Tower (RUNS AND WORKS) (A50774)
2018 Allmand Light...
(8) 2 PLUG VALVES (A52472)
(8) 2 PLUG VALVES...
