Used B7300, what to look for?
   / Used B7300, what to look for? #1
jchewie
Michigan UP
Ford 3000
Any particular problems to note?
Going to check one out today. It is equipped with a FEL and a snowblower.
583 hours.
   / Used B7300, what to look for? #2
Does it have power steering? Without a FEL that probably wouldn't be a big deal on that size tractor. With a FEL it might. Maybe someone who has a tractor that size with a FEL and no power steering will respond. Even better is if you can test drive it with a bucket full.
I'm fairly certain it does not have ps.
   / Used B7300, what to look for? #4
No power steering. The 7300 and 7400 were "discount" B tractors.
Will
Sent from my iPhone using TractorByNet
Reasonable machine? Primary use would be blowing snow, occasional loader use in the winter for snow piles.
   / Used B7300, what to look for? #6
Wish I could help but when you say "blowing snow" a Mississippian might think you are up to no good. :thumbsdown: We don't immediately associate that phrase with frozen water. :laughing:
Did you get it/still considering it?
   / Used B7300, what to look for? #7
I don't know if you would want one with a loader and no power steering, course it would be good exercise and you would have arms like popeye after awhile.
Thanks for the replies!
I decided against this tractor. It seemed like a fine running machine, but not heavy enough and lacking the hp to handle heavy snow.
The current owner is trading up in size for this very reason, and I don't want to be in his shoes wishing I bought the a larger tractor in a year or two.
Other people in the area are happy with the performance of large B series and L series Kubotas and other makes of similar size - so that's what I'm looking at as well.
   / Used B7300, what to look for? #9
If you do not have power steering a counter weight is pretty much mandatory. The heavier the better. With a 400 lb counter weight your steering will become pleasant with a bucket of dirt.
UNUSED WOLVERINE PFF1-13-45W UNIVERSAL MAST (A51248)
UNUSED WOLVERINE...
2025 AGT SDA-140T (A50123)
2025 AGT SDA-140T...
2015 TROXELL 130BBL VACUUM TRAILER (A53843)
2015 TROXELL...
2015 Ford F-550 4x4 Knapheide Service Truck (A51692)
2015 Ford F-550...
(APPROX 18) 2" X 6" X 68" THICK TUBING (A51247)
(APPROX 18) 2" X...
2005 Genie S-60 60ft Telescopic Boom Lift (A51691)
2005 Genie S-60...
