Used B7300, what to look for?
   / Used B7300, what to look for? #1
jchewie
Michigan UP
Ford 3000
Any particular problems to note?
Going to check one out today. It is equipped with a FEL and a snowblower.
583 hours.
   / Used B7300, what to look for? #2
Does it have power steering? Without a FEL that probably wouldn't be a big deal on that size tractor. With a FEL it might. Maybe someone who has a tractor that size with a FEL and no power steering will respond. Even better is if you can test drive it with a bucket full.
I'm fairly certain it does not have ps.
   / Used B7300, what to look for? #4
No power steering. The 7300 and 7400 were "discount" B tractors.
Will
Sent from my iPhone using TractorByNet
Reasonable machine? Primary use would be blowing snow, occasional loader use in the winter for snow piles.
   / Used B7300, what to look for? #6
Wish I could help but when you say "blowing snow" a Mississippian might think you are up to no good. :thumbsdown: We don't immediately associate that phrase with frozen water. :laughing:
Did you get it/still considering it?
   / Used B7300, what to look for? #7
I don't know if you would want one with a loader and no power steering, course it would be good exercise and you would have arms like popeye after awhile.
Thanks for the replies!
I decided against this tractor. It seemed like a fine running machine, but not heavy enough and lacking the hp to handle heavy snow.
The current owner is trading up in size for this very reason, and I don't want to be in his shoes wishing I bought the a larger tractor in a year or two.
Other people in the area are happy with the performance of large B series and L series Kubotas and other makes of similar size - so that's what I'm looking at as well.
   / Used B7300, what to look for? #9
If you do not have power steering a counter weight is pretty much mandatory. The heavier the better. With a 400 lb counter weight your steering will become pleasant with a bucket of dirt.
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A51691)
2025 Kivel 48in...
2013 Ford F-250 Ext. Cab Pickup Truck (A51692)
2013 Ford F-250...
2016 JLG 2032ES Electric Scissor Lift, 369hrs (A52384)
2016 JLG 2032ES...
2007 BobCat S175 Skid Steer (A52384)
2007 BobCat S175...
2025 K731G UNUSED Flower Bed (A53117)
2025 K731G UNUSED...
2012 Dodge Charger Sedan (A51694)
2012 Dodge Charger...
