Use of area in front between lift cylinders
   / Use of area in front between lift cylinders #1
BobRip
Elite Member
Powhatan Va.
2000 Power Trac 422
Has anybody thought to use the area on the PT425 (and maybe other PTs) on the front of the machine below the lift arms and between the lift cylinders? Thoughts come to mind of putting a whinch there or a two inch receiver.
   / Use of area in front between lift cylinders #2
Bob- You could mount your oil cooler there and tie it into the pto return line and then build a carry all bed like I did :D Or you could mount the oil cooler on top of the lift arms. That would make it easier to tie into the pto return.
   / Use of area in front between lift cylinders #3
I added a tow hook to mine. Tow hook picture here.
Also note the size and shape of the front shelf on my 2001 year PT425. I noticed PJ's has a different shape. I think this is due in part to the higher lift height that his has. I think the current 422 chassis is the same as my 2001 year PT425.
Beechwood, thanks for the suggestion. Do you think the oil cooler would be a little too exposed to damage there as you push into dirt or whatever? Putting it on the arms might work. You could add an extra cooler on top of the arms to aid cooling when mowing.
Moss, I remember your tow hook. Good idea. Does it get dirt pushed up in it. If I put a 2 inch receiver there, I wonder if it would fill up with dirt?
   / Use of area in front between lift cylinders #5
I'd keep all hydraulic cooling at the rear of the units.;)
Yes, the tow hook gets debris in it, especially after a long session of brush hogging. For that matter, the entire front of the unit gets several inches of debris on it after brush hogging. It cleans out easily with the leaf blower. As far as dirt, though, I rarely get into that shelf.
Maybe I could mount a tool box there. Just thinking out loud. I probably have enough tool boxes on the PT.
   / Use of area in front between lift cylinders #7
Geez, Bob, your machine already looks like it is outfitted for an African Safari... :D
Seriously, are you still using that roof storage rack filled with all kinds of emergency equipment/tools?
Yes. I tend to keep the less used stuff in the roof rack. Mostly vehicle recovery stuff.
   / Use of area in front between lift cylinders #9
I second the use of MR's tow hook. Probably one of the best add-ons I've done, probably becuase I trailer it alot and the hook is the best place to hook the 2 front tie-downs.
   / Use of area in front between lift cylinders #10
That's the main reason I added mine there; towing the tractor on a trailer. It is the perfect place to chain it down. If I want to tow something with the tractor, I use the rear hitch. I just don't like hooking stuff up under there with the FEL arms raised, so I make it a practice not to unless absolutely necessary, which hasn't occurred yet. :)
2014 Caterpillar 289D High Flow 2-Speed Compact Track Loader Skid Steer (A51691)
2014 Caterpillar...
2018 Wacker Neuson WL 38 (A53472)
2018 Wacker Neuson...
BESTWAY AG VSK50 LOT IDENTIFIER 76 (A53084)
BESTWAY AG VSK50...
2009 Ford F-150 4x4 Ext. Cab Pickup Truck (A51692)
2009 Ford F-150...
2005 Northwood Artic Fox 29V T/A 34ft. 5th Wheel Travel Trailer (A51694)
2005 Northwood...
2015 Infiniti QX60 SUV (A51694)
2015 Infiniti QX60...
