Use of area in front between lift cylinders
   / Use of area in front between lift cylinders
I like the tow hook and have seriously considered it. I actaully made a plate to weld there, but I don't have the courage to weld on the PT. However, maybe there is an even better thing to put there. I really like the two inch reciever, but I think it would be packed with dirt and be hard to clean out. Does anybody else have suggestions?
   / Use of area in front between lift cylinders #12
As I said, I don't like to get under a raised FEL for any reason, and if you have any implement on the front end, that makes it even more dangerous with the added weight and leverage it would have pulling down on you.
And yes, it would definately get packed with dirt and mowing debris. You'd have to keep a plug in it at all times when not in use, I would think, unless you made it open in the rear so a power washer could get in there and blow the debris through.
UNUSED FUTURE XJ5T HYD THUMB CLAMP (A57193)
UNUSED FUTURE XJ5T...
UNUSED FUTURE LS43 HYD WOOD SPLITTER (A57193)
UNUSED FUTURE LS43...
2021 CATERPILLAR 906M WHEEL LOADER (A52707)
2021 CATERPILLAR...
2018 Chevrolet Tahoe SUV (A55853)
2018 Chevrolet...
20-Ton Hydraulic Bottle Jack (A55852)
20-Ton Hydraulic...
2014 MACK ELITE LEU613 GARBAGE TRUCK (A57192)
2014 MACK ELITE...
