URGENT tow drop hook
   / URGENT tow drop hook #11
I believe it is called a "clevis hitch",a common european tractor quick release hitch. But I don't know where the controls are.
   / URGENT tow drop hook #12
URGENT must have figured something out by now.
Jim
   / URGENT tow drop hook #13
Maybee he followed the hoses to the control valve? ;)
many thanks all,it is a european model and it is different to the US models,we have a hook for towing trailers just below the drive shaft.
ive got it sorted ,a cable from the cab just behind the drivers seat to the right was missing.
THANKS ALL
Neil
   / URGENT tow drop hook #15
The hitch you are referring to is a pick up hitch, the hitch picks the trailer tongue up, they are extremely popular in the UK and are non existent in the USA. Some of these where actuated off of the rear three point of the tractor, when the 3pt was down the hitch was also down. However you could disconnect the hitch and pin it up, perhaps yours needs connected to the rock shaft on the 3 point? Other units used a separate hydraulic cylinder and valve to control the hitch, however this was more common on the larger tractors.
Sportsman your smack on,we have a seperate cylinder on ours,got it working .
Thanks for all the help.
neil
2015 Ford Escape SUV (A56859)
2015 Ford Escape...
LOT: (6) Office Chairs (A59076)
LOT: (6) Office...
2012 DOOSAN G25KW GENERATOR (A55745)
2012 DOOSAN G25KW...
EquipmentDealz (Preview Dates and Times) (A59213)
EquipmentDealz...
Case-IH 165 Puma (A57148)
Case-IH 165 Puma...
EZ-GO Utility Cart (A55853)
EZ-GO Utility Cart...
