URGENT- help needed for newbie
/ URGENT- help needed for newbie #1
molsongoldon
Please excuse my lack of understanding, but need you guys to help.
I have a 4 year old Sears DYT-4000 yard tractor with a Kohler 20hp engine. Never had a problem until today.
The engine runs great, but is now making a strange tapping noise. It is getting louder. All I have done in the last year is replace the oil with OEM filter and recommended oil.
I first thought it was a loose exhaust- no, maybe a blown plug- no. My neighbor thinks it is a blown head gasket?
Any ideas? i can give more information as we get wquestions. i am going to contact kohler and am reading about a known head gasket issue with older models.
/ URGENT- help needed for newbie #2
Depending on the speed of the tap as compared to the engine speed, it could be a rod bearing or a sticky valve.
If it sounds roughly like it's at the same speed as the engine, rod, if it sounds slower (about the same as the exhaust "pop" at the muffler at idle) it's a valve.
Check the oil for metal. Get some of the oil on a plate, or anything non absorbent, and look at it in strong light. You don't want to see anything "sparkle", or have it be very black in color.
You can also rub some of the oil between your fingers and see if it feels rough.
Wineslob,
engine oil is brand new and "clear". no abrasive feeling to it. I have read that the sticky valve was a problem and addressed by synthetic oil use?
Just not sure why all of a sudden this would creap up.
/ URGENT- help needed for newbie #4
Are you sure it is coming from the engine? Nothing that the engine is connected to like a pulley and belt? Does it make a difference if you engage the clutch or not? All hardware on the engine tightened down like cowlings and filters and engine mounts? Start with the easy things first.
/ URGENT- help needed for newbie #5
If you put the wrong oil in it the lifters may not be pumping up??? Lots of issues if you put the wrong oil in it.
/ URGENT- help needed for newbie #6
Hi Mr Molson!
Try the shade-tree mechanic's stethoscope: a piece of broomstick or a long screwdriver. Put one end of the broomstick (or the screwdriver handle) against your jaw joint, pressing the little flap of flesh back to close your ear canal, then move the other end to various locations on the engine, frame, etc. You will be hearing the internal engine sounds by bone conduction and shutting out exhaust noise, etc. You may want to put a finger in your other ear also, just to shut out external noise. I learned this trick from a mechanic.
Good luck!
Tex
/ URGENT- help needed for newbie #7
when my 15ys old 700$ murray started doing that this year I though it was getting ready to throw a rod.. turned out that the 4 lag screws ( YES! ) that pass thru the frame into the base of the engine block to mount the engine to the tractor were ALL loos and the engine actually hammered in a rotational manner as the cyl fired.. tightened it up.. all fine now.. worth a look..
soundguy
/ URGENT- help needed for newbie #8
+1
Doubtful that it's lifters, they are "solid" (not hydraulic) in these kinds of engines.
/ URGENT- help needed for newbie #10
G'day kohler had a prob with blowing head gaskets on some of their engines their fix was a new style head gasket and new head tensions as well as a modified flywheel/ flywheel key to adjust the timing. They were doing this mod over here as a warranty job on select engines that were well and truly out of warranty can't say wether yours would be covered but may be worth a try at the local agent. They also had a prob with flywheel ring gears breaking and making a **** of a racket also been known to take out coils when they go and i know that this is an indefinite warranty fix on these engines over here at the moment. Good luck with yours though:)
Jon
Solution found:eek:
I was able to finally work on the tractor. Sometimes the obvious is the best to look at. I found that where the exhaust pipe off the engine attaches to the muffler there is a collar that was only spot welded (if at all). the weld broke and the collar was flopping inside the muffler. Becasue the muffler is crimped it cannot be opened with ease. I was able to grab the collar and using ss rivets get it back in place. Even better than new. Started the engine and voilla, no more noise. save some pennies too.
FYi, removingthe exhaust pipe off the engine is tricky, the two bolts are actually studs and cease very easily. A torch and some lock-free took care of the broken post. $8.50/ ea at sears, but the are M-8's and $2.25 at the local hardware store.
Not bad for a novice i think.
/ URGENT- help needed for newbie #12
Congrats on the repair. Awesome when you can diagnose, and fix the problem. Gives you confidence to build on so you can attack the next one. Good luck!
/ URGENT- help needed for newbie #14
Great job analyzing the problem and addressing it! BTW, someone wrongly mentioned that the engine has solid lifters, they do have hydraulic lifters and require use of 10W-30 oil, or if above 55 degrees can use straight 30W oil.
Muffler baffles breaking loose inside the muffler was a frequent problem on these tractors, resulting in the RH cylinder (as viewed when seated on tractor) running very hot, eventually taking out the head gasket on that cylinder;glad you caught your issue in time!
2008 HINO 268 4X2 26FT NON CDL BOX TRUCK (A59910)
2008 HINO 268 4X2...
Cat 3-4 quick hitch (A64047)
Cat 3-4 quick...
2007 Dodge Ram 1500 4x4 Crew Cab Pickup Truck (A61568)
2007 Dodge Ram...
(APPROX.100) 23"X95" EXPANDED METAL (A62130)
(APPROX.100)...
YALE VERACITOR 50VX STRAIGHT MAST FORKLIFT (A63276)
YALE VERACITOR...
UNUSED WOLVERINE 8' FORK EXTENSIONS (A62131)
UNUSED WOLVERINE...
