3-Point Hitch Upper Stop on the Posituon Control Lever
   / Upper Stop on the Posituon Control Lever #1
WillWitten
Mahindra 4025
I would like to adjust the UPPER limit on the draft control lever. I cannot figure out how to loosen it. There are no Allen/hex holes to loosen it. I tried a vice grip and I can't get it to turn-loosen. The lower limit stop moves just fine. It has a plastic wing nut on it that. Works well.
Has anyone else moved the upper limit?
I have a new 4025 (28 hours now).
   / Upper Stop on the Posituon Control Lever #2
Will.
I believe the upper limit stop is set at the factory and they do not want you to adjust it. Somewhere in the back of my mind I remember reading that in the manual somewhere.
   / Upper Stop on the Posituon Control Lever #3
I also own a 4025 with 23 hours and the manual definetly says " do not adjust the factory setting". I would leave it as is and try to find another solution.
Good luck
   / Upper Stop on the Posituon Control Lever #4
Your subject says 'position control' and the msg text says 'draft control'. Which are you trying to move?
Oops... I mean the "position" control.
I used the wrong word in the body.
(10) 8' Treated Posts (A50515)
(10) 8' Treated...
New Holland 499 Hydra - Swing Mower Conditioner (A50514)
New Holland 499...
2017 CATERPILLAR 305.5E2 CR EXCAVATOR (A51242)
2017 CATERPILLAR...
2021 Doosan DX350LC-5 Hydraulic Excavator (A49346)
2021 Doosan...
2008 Ford Escape XLT SUV (A51694)
2008 Ford Escape...
2025 Swict 78in Bucket Skid Steer Attachment (A50322)
2025 Swict 78in...
