3-Point Hitch Upper Stop on the Posituon Control Lever
   / Upper Stop on the Posituon Control Lever #1
WillWitten
Mahindra 4025
I would like to adjust the UPPER limit on the draft control lever. I cannot figure out how to loosen it. There are no Allen/hex holes to loosen it. I tried a vice grip and I can't get it to turn-loosen. The lower limit stop moves just fine. It has a plastic wing nut on it that. Works well.
Has anyone else moved the upper limit?
I have a new 4025 (28 hours now).
   / Upper Stop on the Posituon Control Lever #2
Will.
I believe the upper limit stop is set at the factory and they do not want you to adjust it. Somewhere in the back of my mind I remember reading that in the manual somewhere.
   / Upper Stop on the Posituon Control Lever #3
I also own a 4025 with 23 hours and the manual definetly says " do not adjust the factory setting". I would leave it as is and try to find another solution.
Good luck
   / Upper Stop on the Posituon Control Lever #4
Your subject says 'position control' and the msg text says 'draft control'. Which are you trying to move?
Oops... I mean the "position" control.
I used the wrong word in the body.
2015 FORD F-250 XL SUPER DUTY TRUCK (A51406)
2015 FORD F-250 XL...
2007 Kubota M5040D 50HP 4WD Front Loader Utility Tractor (A50322)
2007 Kubota M5040D...
2018 Toyota RAV4 Hybrid XLE AWD SUV (A50324)
2018 Toyota RAV4...
Electric Scissor Lift (A50322)
Electric Scissor...
2015 Nissan Pathfinder SV SUV (A50324)
2015 Nissan...
Case SV 340 Skid Steer Loader (A52349)
Case SV 340 Skid...
