3-Point Hitch Upper Stop on the Posituon Control Lever
   / Upper Stop on the Posituon Control Lever #1
WillWitten
Mahindra 4025
I would like to adjust the UPPER limit on the draft control lever. I cannot figure out how to loosen it. There are no Allen/hex holes to loosen it. I tried a vice grip and I can't get it to turn-loosen. The lower limit stop moves just fine. It has a plastic wing nut on it that. Works well.
Has anyone else moved the upper limit?
I have a new 4025 (28 hours now).
   / Upper Stop on the Posituon Control Lever #2
Will.
I believe the upper limit stop is set at the factory and they do not want you to adjust it. Somewhere in the back of my mind I remember reading that in the manual somewhere.
   / Upper Stop on the Posituon Control Lever #3
I also own a 4025 with 23 hours and the manual definetly says " do not adjust the factory setting". I would leave it as is and try to find another solution.
Good luck
   / Upper Stop on the Posituon Control Lever #4
Your subject says 'position control' and the msg text says 'draft control'. Which are you trying to move?
Oops... I mean the "position" control.
I used the wrong word in the body.
2016 Ford E-350 Enclosed Service Van (A50323)
2016 Ford E-350...
Walking Floor Trailer (A50322)
Walking Floor...
2020 CATERPILLAR 289D3 SKID STEER (A51242)
2020 CATERPILLAR...
2019 RBR Venturi 380 (A52128)
2019 RBR Venturi...
2015 BOBCAT E35 EXCAVATOR (A51242)
2015 BOBCAT E35...
2010 KENWORTH T270 SERVICE TRUCK (A51243)
2010 KENWORTH T270...
