Upgrading Mobile Home Axles??????
   / Upgrading Mobile Home Axles?????? #21
I have a trailer with mobile home axles that were adapted to fit conventional rims. The tabs were ground off the hub and an adapter plate was mounted that fit regular rims.
I really hope you're kidding...
   / Upgrading Mobile Home Axles?????? #22
Nope. Serious as a heart attack.
I didn't do it. It was that way when I bought it, but it's worked great for me.
   / Upgrading Mobile Home Axles?????? #23
I am building a 6X14 trailer right now, it will have a #6000 MH axle converted to 6 hole wheels, $32 each hub. I am buying a brake axle with 6 bolt hubs.
A trailer supply company will be able to tell you if your MH axles can be converted.
I have a 16 foot trailer with MH axles and had trouble finding any more used tires in this area. Found new "Towmaster" brand tires for $75 each, on the sidewall they say "trailer use only"......NOT mobile home use, so I think I'm legal anywhere....
   / Upgrading Mobile Home Axles?????? #24
Tow Master tire are a quality trailer tire made by Greenball so you are in luck.
Chris
   / Upgrading Mobile Home Axles?????? #25
Swap it to 8 lug drums if you have the correct brake backing plate mount.
  • Moblie Home axles.pdf
   / Upgrading Mobile Home Axles?????? #26
Where did you get the hubx? Are they brake hubs?
   / Upgrading Mobile Home Axles?????? #28
Hi I didn't get all is there a way to up great the (MH) axel yes or not because I have problems whit my trailer also if not I live in springdale,AR is there any bady who let me now were I can find some use 6 logs axel and wheels or some bady out there has ones for sale please let me now
   / Upgrading Mobile Home Axles?????? #29
Say what?????
Chris
   / Upgrading Mobile Home Axles?????? #30
I have a mobile home 18K heavy duty tri-axle trailer with brakes on each axle. It is titled and registered as a legal use trailer in the state and has DOT accepttable tires. I purchased this trailer when I was less informed and the fact it was a good deal. I thought I was just fine but it was not only the MH axles that were a question but the fact the trailer was built on a MH frame. When pulling with my larger truck over 8,000 lbs (heavy truck) I needed a separate policy than my personal vehicle truck and sure enough they would not cover it without a manufacturer plate VIN - number and GVWR rating. The insurance cost would of been only a few dollars but no insurance it no insurance. At the end of the day, the risk of having something go wrong on this traielr and being sued was too high a risk to take when going down the road. It is hard to debate that the original design of the axle and frame was for a temporary mobile home transport. So in the end I purchased a different trailer and the "peace of mind" alone has been worth it. I am willing to take a lot of risks but this was just not one of them.
2016 Ford Transit 250 Passenger Van (A55852)
2016 Ford Transit...
Great Dane Van Trailer 1989 (A56438)
Great Dane Van...
2010 Ford F-550 4x4 Venturo HT40KX 3 Ton Crane Mechanics Truck (A59230)
2010 Ford F-550...
International 9200 (A56438)
International 9200...
2014 Ford Escape SUV (A55853)
2014 Ford Escape...
EXCAVATOR JACKHAMMER (A58214)
EXCAVATOR...
