Upgrading loaders
/ Upgrading loaders #1
design
Southern, NH
M5400
Has anyone ever changed out the main cylinders on a kubota loader to increase the lift capacity?
I am looking at a L2900 4WD with a LA480 loader, and the loader capacity is less than I desire. The front axle is off of a L3300 if that makes a difference.
Design
/ Upgrading loaders
Design
/ Upgrading loaders #3
design, Would increasing the size of the hydraulic cylinder increase the load capacity or would you also have to change the hydraulic pump (big money) in order to pressurize the larger cylinder correctly plus frame, weight of machine, design specifications of pins and fittings HMM! sounds like maybe a bigger tractor should be on your wish list rather then overstressing your current machine sell it before it gets bent out of square by tweaking the loader frame and mounts and put the money towards a bigger tractor if you go big enough it may even be less expensive then the one you've got if you pick up a good used one, though if you have implements they'd be to small possibly. Maybe a package deal swap with a retiring farmer who's looking to downsize.
Steve
John Deere R15 Rotary Cutter (A64047)
John Deere R15...
2009 International 4300 Box Truck 24' (A62613)
2009 International...
KBH Tender Trailer (A63688)
KBH Tender Trailer...
JOHN DEERE 8' OFFSET DISC HARROW (A64276)
JOHN DEERE 8'...
Caterpillar 963C/953C Track Loader Service Manuals (A63117)
Caterpillar...
PJ Trailers 84"x15' Roll Off Dumpster (A60462)
PJ Trailers...
