Upgrades to my Kubota L3010
   / Upgrades to my Kubota L3010 #12
Thanks for the kind words everybody!
BD: You have to tell me more about that! Is that a clevis mount under there? (maybe start a new thread so we dont derail the OP's thread)
KennyD, Yes, this is a clevis mount. I milled a piece of square stock and drilled a precision hole for mounting. Easily removable so I can use it with a chain. This hook is for moving my 6 foot brush hog around in the Garage. A gentlemen from Erie PA inspired me to make this on TBN. He had made something similar for his Kubota tractor and I saw a photo of it.
   / Upgrades to my Kubota L3010 #13
Some add on's I put on my (07) L3400 DT, I have over a dozen attachments/accessory's I've added on the tractor, just so I can get firewood/logs out.
Can you see the fuel filter, all I could see is a stick hitting it, so this is the first thing I added when I bought the tractor, 2 bolts holds it on.
I needed away to hold my chain saw, this saw holder slides in between the loader and frame, about a 1/2" gap, I tried putting the saw in the bucket, ONCE!, then I starting to use the loader, only took me ten minutes to forgot the saw was in the bucket.
After a couple times of breaking the winch cable on this Fransgard logging winch, and trying to get the spool out, I had to modify it. If you look close, you can see two, 1/2" bolts, two on both sides of the frame, makes it easy now to change/fix cable.
2010 Toyota Corolla LE Sedan (A50324)
2010 Toyota...
2008 Hino 268 Truck, VIN # 5PVNJ8JV582S51513 (A51572)
2008 Hino 268...
2000 Freightliner FL70, 5.9 Cummins (A52384)
2000 Freightliner...
2004 Sterling L8500 4,000 Gallon T/A Water Truck (A50323)
2004 Sterling...
2007 JLG SkyTrak 10042 10,000lbs 4x4 Rough Terrain Telehandler (A50322)
2007 JLG SkyTrak...
2018 Chevrolet Tahoe SUV (A50324)
2018 Chevrolet...
