Upgrades to my Kubota L3010
   / Upgrades to my Kubota L3010 #12
Thanks for the kind words everybody!
BD: You have to tell me more about that! Is that a clevis mount under there? (maybe start a new thread so we dont derail the OP's thread)
KennyD, Yes, this is a clevis mount. I milled a piece of square stock and drilled a precision hole for mounting. Easily removable so I can use it with a chain. This hook is for moving my 6 foot brush hog around in the Garage. A gentlemen from Erie PA inspired me to make this on TBN. He had made something similar for his Kubota tractor and I saw a photo of it.
   / Upgrades to my Kubota L3010 #13
Some add on's I put on my (07) L3400 DT, I have over a dozen attachments/accessory's I've added on the tractor, just so I can get firewood/logs out.
Can you see the fuel filter, all I could see is a stick hitting it, so this is the first thing I added when I bought the tractor, 2 bolts holds it on.
I needed away to hold my chain saw, this saw holder slides in between the loader and frame, about a 1/2" gap, I tried putting the saw in the bucket, ONCE!, then I starting to use the loader, only took me ten minutes to forgot the saw was in the bucket.
After a couple times of breaking the winch cable on this Fransgard logging winch, and trying to get the spool out, I had to modify it. If you look close, you can see two, 1/2" bolts, two on both sides of the frame, makes it easy now to change/fix cable.
Woods BW12 Batwing Mower (A50514)
Woods BW12 Batwing...
2021 John Deere 333G Compact Track Loader, 390 Hours, High Flow Hydraulics, Ride Control (A51039)
2021 John Deere...
2015 CATERPILLAR 336FL EXCAVATOR (A51242)
2015 CATERPILLAR...
2013 INTERNATIONAL PAYSTAR DAY CAB ROAD TRACTOR (A51406)
2013 INTERNATIONAL...
2008 MAGNUM LIGHT PLANT (A50854)
2008 MAGNUM LIGHT...
2014 ORTEQ ENERGY SERVICES MANIFOLD TRAILER (A50854)
2014 ORTEQ ENERGY...
