upgrade
/ upgrade #4
If Kubota offered a Cabbed BX Series tractor, they would sell like hotcakes!
According to Neil, the BX series tractors are the largest selling Tractor in the US Kubota line.
Sure you can get a Curtis Cab for your BX, but it’s $5K
Kubota, if you’re listening, sign me up!
Cheers,
BN
/ upgrade #5
In the for what it’s worth department, I started the tractor journey with a BX and gradually upgraded to a cab grand L, which I absolutely loved great tractor however, when my my wife went into a nursing home two years ago, I decided to to downsize to a smaller tractor and bought a BX 2680 great little tractor. I quickly found one limiting factor and that was its lifting capacity with pallet forks. It would only live 300 pounds safely. I start looking around and finally settled on an LX 2620 cab, once you’ve had a cab tractor. It’s hard to go somewhere else. The LX has the lifting capacity and yet it uses all the same implements of my BX so I don’t have to buy new implements. I’ll have to admit I’m keeping the BX at least for the time being number one trade-in value with only 38 hours on it was not very Good and secondly, it’s nice to have so I don’t have to keep switching implements so I keep some of my lightweight and smokes on the BX and the heavier used ones on the LX whichever way you go I would strongly suggest at delivery. You have a third function valve put on whether you plan to use third function implements or not you will eventually a grapple is a great tool to have for moving brush around and if you’re up north it works for the snowblower as I said my two cents worth
Landhonor HPF-11-3000G, 48" Heavy Duty Forks (A62679)
Landhonor...
Lonestar Panel 24ft. Free Standing Panel with Feed Bunk (A65640)
Lonestar Panel...
Covered Livestock Mineral Feeder (A66408)
Covered Livestock...
2023 CATERPILLAR 259D3 SKID STEER (A64279)
2023 CATERPILLAR...
TEST YOUR BID BUTTON! (A64277)
TEST YOUR BID...
Connect CH65 Hydraulic Breaker Excavator Attachment (A64194)
Connect CH65...
