Update: 3PH won't raise...
/ Update: 3PH won't raise... #1
Paddy
Bloomington, IN
Kubota, G5200, KAMA 454
A while back I posted that my KAMA 454's 3PH would not raise due to interfearence from an impliment and the draw bar. I have been traveling a bit lately and I took some time today to replace the lift valve assembly.
IT WORKS! Thanks Chip (and your mechanics) for all the advice as I called in repeatedly.
/ Update: 3PH won't raise... #2
That's great news!
If you decide to dissect the bad valve I am interested in what broke.
I too am interested in the cause of failure. According to the diagram, there are several relief valves. Chip and I concluded that the relief valves probally did there job just fine, (for awhile!). But after ten hours they must have given up. I'd like to repair so I have a spare for the next time I do a bone head thing!
/ Update: 3PH won't raise... #4
The reliefs probably got way hot from constant bypassing.. and the springs got weak.. thus making them bypass at a lower psi.. or just stay bypassed.
Constantly bypassing valves are also prone to stick open if there is any trash circulating ( new systems with filters are less prone to this ).
Soundguy
/ Update: 3PH won't raise... #5
Had the same symptom on my KAMA 554 last summer. It turned out to be a loose locknut on the float linkage inside the 3ph case.
My linkage was loose too. I tried tightening, no luck. I tried adjusting by shortening and lenghtening, no luck. The only thing that worked was bumping the FEL control. All fixed now but I will dissasemble some day
KMC 13 SHANK H.C. CHISEL PLOW, 3PT (A64278)
KMC 13 SHANK H.C...
2022 CATERPILLAR 272D3 SKID STEER (A65053)
2022 CATERPILLAR...
2018 International WorkStar 7300 4x4 2,000 Gallon Water Truck (A64556)
2018 International...
2023 WACKER NEUSON G70 TOWABLE GENERATOR (A63276)
2023 WACKER NEUSON...
2023 BARRETO E30SGB WALK BEHIND STUMP GRINDER (A63276)
2023 BARRETO...
2015 GMC Yukon XL Denali SUV (A64557)
2015 GMC Yukon XL...
