Update: 3PH won't raise...
   / Update: 3PH won't raise... #1
Paddy
Veteran Member
Bloomington, IN
Kubota, G5200, KAMA 454
A while back I posted that my KAMA 454's 3PH would not raise due to interfearence from an impliment and the draw bar. I have been traveling a bit lately and I took some time today to replace the lift valve assembly.
IT WORKS! Thanks Chip (and your mechanics) for all the advice as I called in repeatedly.
   / Update: 3PH won't raise... #2
That's great news!
If you decide to dissect the bad valve I am interested in what broke.
I too am interested in the cause of failure. According to the diagram, there are several relief valves. Chip and I concluded that the relief valves probally did there job just fine, (for awhile!). But after ten hours they must have given up. I'd like to repair so I have a spare for the next time I do a bone head thing!
   / Update: 3PH won't raise... #4
The reliefs probably got way hot from constant bypassing.. and the springs got weak.. thus making them bypass at a lower psi.. or just stay bypassed.
Constantly bypassing valves are also prone to stick open if there is any trash circulating ( new systems with filters are less prone to this ).
Soundguy
   / Update: 3PH won't raise... #5
Had the same symptom on my KAMA 554 last summer. It turned out to be a loose locknut on the float linkage inside the 3ph case.
My linkage was loose too. I tried tightening, no luck. I tried adjusting by shortening and lenghtening, no luck. The only thing that worked was bumping the FEL control. All fixed now but I will dissasemble some day
2018 Case TR270 High Flow 2-Speed Compact Track Loader Skid Steer (A51691)
2018 Case TR270...
2022 Weber MT CF2A Plate Compactor (A51691)
2022 Weber MT CF2A...
TMA (A49461)
TMA (A49461)
2016 Ford F-450 12FT Flatbed Truck (A51691)
2016 Ford F-450...
1999 Ford F-550 12FT. Flatbed Truck (A51692)
1999 Ford F-550...
