Loader Unlevel bucket
/ Unlevel bucket #41
Not the cylinders, bucket will not flex that much. Prove it by disconnecting cylinders
at one end with bucket touching the ground, it'll still be off. Air pressure checked?
Measure the height at the center of each rim/axle end, there are a lot of people
reporting tires that are not the same height as each other
/ Unlevel bucket #42
.... Measure the height at the center of each rim/axle end, there are a lot of people
Mismatched tires is an interesting possibility. While it might be hard to get an accurate vertical measurement in a deep dished rim, swapping mismatched tires from side-to-side should change the bucket tilt direction. Or measure their circumferences on the floor.
/ Unlevel bucket
Everybody keeps mentioning tires and tire pressure. If it was either of those then the whole frame of the tractor would be uneven with a flat surface such as my driveway but it's not. One of the pictures I included earlier shows that the bucket and frame of the tractor are uneven with each other. It could be that the frame of the FEL itself is the issue. I know that if I take the bucket off so that only the FEL arms are there, the left arm touches the surface before the right one. Only way I know to determine if it's the FEL or cylinders is to disconnect one end of each cylinder then do a measurement of each cylinder. Since several of us owners are seeing the issue I feel that RK needs to do some investigating. Maybe even check the tractors they have sitting on the lot to see if they might have one right there.
/ Unlevel bucket #44
It would be nice if Doug (RKTractorGuy) could weigh in on this. With his industry experience and involvement with RK now, I imagine he could offer some input/solutions.
/ Unlevel bucket
I was told today that a matched set of cylinders are being ordered for my issue. Woohoo, maybe is the near future I can use my bucket to do some ground leveling. Happy days are here again.
/ Unlevel bucket #46
Don, who made the decision to get those ordered for you? Store level, corporate?
I looked at my bucket/FEL when it was raised, and empty and it was very noticeable.
/ Unlevel bucket #47
Did anyone measure both left and right cylinders either fully extended or retracted? Or did I miss that post?
What happens if you go to max lift? Will it twist the loader arms and get straight? That would prove that the loader arms are bent.
I don't think the problem is on the cylinders. What are the odds of putting one cylinder longer on various tractors?
To me, it seems like the loader manufacturer has a problem on the welding jig for the loader arms, therefore causing all these problems. They might not have realize the problem though.
/ Unlevel bucket #48
I agree with this, it is not the cylinders.
The cylinders can be removed from the loader frame,, and the bucket will still show the same twist.
Try it, if new cylinders are coming, you will need to remove the cylinders anyways,,,
set the bucket on a saw horse,
with the bucket supported, remove the lift cylinder, and lay it on the ground,,
The bucket, sitting on the saw horse will not "twist" the frame.
The saw horse can be under the right side, the saw horse can be under the left side,,
it will not matter,, the unlevel bucket will remain unlevel.
You can also remove one cylinder, and chain the removed cylinder in the closed position while it is on the ground.
the other cylinder will now move the loader arms through the travel range.
it does not matter which cylinder is removed, left or right, the bucket will remain unlevel.
The side that is high, will remain high,,
You can test this, and prove the cylinders are not the problem by simply removing one cylinder.
/ Unlevel bucket
Gunny, I don't know if the decision was made at the store or corporate level. I went in the store to pick up horse feed he called me aside and told me that Monday the cylinders would be ordered. He said they just replaced a set on another tractor but it was the bucket cylinders, not the arms. I mentioned that I was wondering if possibly the FEL arms might not be welded correctly but he didn't seem to be too concerned it was them. All I know is that there's an issue and they need to fix it so I can use the bucket.
/ Unlevel bucket #50
I’m taking more pictures tomorrow. With the loader raised in the air, while parked on a level surface, it is noticeably off and uneven. While this might be acceptable to some - it is not for me. I spent close to $42000 at the local store, in cash. This was my retirement money.
I know this isn’t a piece of construction equipment. But on the hood it says “performance series”. I’m slightly miffed that this issue is being dismissed because the quality of the tractor isn’t that of a $100000 excavator.
I understand flaws. I understand that the floormat might not stay down on the floor - as is the case in mine. And I am constantly tripping on it when getting in the cab. I can overlook this and trim a slight excess of rubber matting on my own.
I expect some growing pains. But I don’t expect a tractor that is sold on so much hype about how long they’ve been in service, who makes the engine, the history of the company - all to have a loader that won’t sit level on the ground. Why is there no interest in this?
I was told that there is plenty of mention with other tractor manufacturers on this forum and the topic of unlevel or uneven loaders. I haven’t been able to find much about others, except the RK.
Yes I’m new to RK tractors. Yes the only other tractor I had was a 1978 ford gear tractor. But I’m not new to quality and service. If something isn’t right it should be addressed by more than a couple of guys hypothesizing about the cause. We can prove there’s a problem. We just need them to address it.
Sorry for the rant. But it bothers me every time I walk out to my shop and see my tractor backed in and the loader facing me.
/ Unlevel bucket #51
I'm not an RK owner but I got the impression that RK was monitoring TBN, to their credit. They probably still are. Weird...
/ Unlevel bucket #52
I park my tractor on a level concrete slab underneath a carport and I keep the sharp part of the bucket pointed toward the slab to keep rain out of the bucket since it sticks out of the carport a bit. Last I checked the rear wheels were at the same pressure. The left side of the bucket (looked at from the driver seat) hits the slab about 1-2 inches before the right side. I'll do some more investigating when I get a chance with the bucket in the flat position and post results.
/ Unlevel bucket #54
So I just came across this thread. My tractor is sitting at the dealer right now for an insurance claim on my loader, because the loader mounts on the tractor bent, and it was pretty much stated it was my problem due to using the root rake as a root rake... No big deal I can swallow it. The issue I have however is if multiple people are having this issue then somebody from RK needs to give an explanation. My tractor also has a warranty claim right now due to the 3 point controls being so tight that I had to rent another piece of equipment to finish grading a driveway pad because the tractor couldn't cut the mustard. I am really starting to get a bitter taste in my mouth with my RK considering what I have spent.
/ Unlevel bucket #56
What are your sources on this info? I messaged him (through FB messenger) over the weekend (about something unrelated) and got a response.
If RK is aware but silent, then I'd speculate they're worried about legal issues here.
/ Unlevel bucket
I got a call yesterday that the new cylinders are in. Looking to rent a trailer and take a couple days off work to haul the tractor down to the store. PorkChop, why in the world would they say it's because you used a root rake when RK sells grapples for that purpose. Maybe they really meant for the grapple to be used to pull Spanish moss out of the trees. If the cylinders don't fix it I guess they'll have to change the loaded next. I've been holding off on buying their grapple until it'll sit level.
/ Unlevel bucket #58
I'm guessing the cylinders won't help, but keep us updated!
/ Unlevel bucket #59
The cylinders do not and are not intended to work in sync. The cylinders aren’t even because the frame isn’t even, not the other way around. Don’t believe me? Take the loader off the tractor while leaving the hoses hooked up and back away as far as the hoses will allow. Now operate the raise and lower function. Changing the cylinders will make no difference.
/ Unlevel bucket
With as many folks that have spoken up about having this issue since I first posted the issue back in April, I also have my doubts but they asked for pictures of the cylinders and so forth so I complied. I have a feeling that the manufacturer of the loader has an issue with the jig that holds the loader together for welding might not be completely in alignment but then again the loaders for the 24, 37 and 55 are all different so that would mean each jig would be off.
2001 Kubota L3300F 35HP Utility Tractor with Caroni TC710 6ft. Rotary Brush Mower Attachment (A59228)
2001 Kubota L3300F...
2017 Ram 5500 Bucket Truck (A63689)
2017 Ram 5500...
90in. Work Bench (A65640)
90in. Work Bench...
2012 John Deere 6125M (A64126)
2012 John Deere...
New/Unused Pallet of Webbing Slings (A65583)
New/Unused Pallet...
2022 YANMAR VIO35-6A EXCAVATOR (A63276)
2022 YANMAR...
