unknown manure spreader
/ unknown manure spreader #1
pinedawg
Kubota L2900
Does anyone know what brand/ model # of spreader this may be? I gave $300 for it and it broke on the second load. It works fine, just needs some frame reinforcements and a few parts. I can make most of what I need but there is an idler missing and a part to lift the chain of the sprocket that I would like to buy or replicate if I can.
Thanks,
sorry...forgot to add the pics
/ unknown manure spreader #3
I'm guessing New Holland, maybe a 300 series, built in 1953.
/ unknown manure spreader #4
My first reaction was New Holland also.(paint colors) After looking closer, I see a few things that remind me of International Harvester. Look closly at any castings for part #'s. That can be a good indicator.
/ unknown manure spreader #5
My guess is a new idea.
mark
/ unknown manure spreader #6
looks very similar to my new idea. there should be a tag of some sorts up near the front, if its a new idea. the only thing i would be wary of is the condition of the apron chain, if it wasn't well kept it may last only a few loads. i would def load it light the 1st few loads. some of the old spreaders have an odd type of apron chain, they can be a pain to work w/ and find parts for. once you get it back into working shape and use it i would def oil the chains and wood sides/floor after every use, its the saving grace for the older spreaders esp if it sits outside.
/ unknown manure spreader #7
Don't mean to hijack this thread, but I've got a friend that picked up a well kept Allis Chalmers (PTO drive). One thing though, the floor is rotted thru. What's the best way to replace the flooring??/ By the way, it looks like a New Idea to me as well...Thanks, BobG in VA
/ unknown manure spreader #8
BobG,
Mine has a thick oak floor that for its age is in very good shape. I would not want a metal floor. My chains are a little rusty but everything works just fine.
mark
Thanks to all for the help so far. It did have a small tag on the front of the frame, but it has been painted over several times and I couldn't get any information off of it. I oiled and greased it big time before I used it, but the frame broke taking it across the field on the second load. I plan on tearing it down between Thanksgiving and Christmas and restoring it to good working order. The one load I did spread came out great......just had to be a bummer and break after that. I knew it would need some work when I bought it, just not right away. It needs a new floor too...so when I do it all, I'll just go through it. Some friends of mine own a nice fab shop and they already told me to bring it on in. I help them out sometimes and get free use of the shop whenever I need it. They make hay unrollers and have all kinds of access to chains and sprockets, etc.....
I'll keep you posted and update the redo pictures when I get er done.
Thanks again,
James
/ unknown manure spreader #10
New Idea... right...
mark
/ unknown manure spreader #11
bob if the floor needs replacing it can be done. you will need to remove the apron chain/bars that span the floor. for that open a link in the apron chain which may be a big pain in the rear, then you should be able to pull the whole assembly chain and bars out from the back def will need some extra hands for that. then try to measure the size planks you need, i would def get hardwood oak is best then treat them and put them in. should last another 20 yrs or better w/ care after use ie a good washing and coating of oil works best.
John Deere Z997R (A60462)
John Deere Z997R...
2005 Manac 48' x 102" Aluminum Fixed Spread Axle Trailer (A62613)
2005 Manac 48' x...
New/Unused AGT Industrial SDA-140T Track Loader (A65583)
New/Unused AGT...
John Deere 4039TF001 (A64127)
John Deere...
2019 CHEVROLET SILVERADO 2500HD (A65643)
2019 CHEVROLET...
New/Unused Wolverine 66in Quick Attach Smooth Bucket (A65583)
New/Unused...
