Unfathomable
/ Unfathomable #41
Just think how much more practical a 7 hp diesel engine would be. A 7 hp vehicle is pretty much useless though. That's half the power in a heavier vehicle than my Mule.
/ Unfathomable #42
Was just a proto type showing it's possible
/ Unfathomable #43
Its no coincidence e JD is introducing this at SIMA in France. 80% of France's electricity is generated by nuclear energy. French tend to accept technology more readily than other countries. It will be interesting to see how close this is to an actual feasible tractor rather than a novelty intended for a technology splash at SIMA where high tech is always on the venue.
/ Unfathomable #44
I don't think charging times will be as bad as you think. Tesla currently does 120kW(seriously, it's awesome to behold 300A @ 400VDC straight to the pack) charging today which can take a 90kW pack from 0-75% in 45 minutes. It's all about charging in parallel and getting in the right taper zone. The pack voltage here looks like 650V which means they can charge more packs in parallel since Tesla only does 400V. I could easily see 30mins charging time(lunch break) with proper 3-phase power install.
As long as they have good cooling they should be okay in terms of longevity. Teslas are currently showing 2-3% degradation over 100kmi which is pretty great. Personally I'm showing 1% at 43k.
Fuel costs + lower maintainence are the winner here. Currently a full "tank" which gets me 270mi costs me $6 in electricity compared to the 2 gallons you get in equivalent diesel prices here. No need to haul/store fuel either which is a big benefit one of the sheep farms out in Ireland had when they went to electric all ATVs.
I'll post more thoughts later but super excited to see this happen. Electric doesn't make sense everywhere but there's certainly areas where I think it's worth considering.
Wow, 120 kW charging load!!! That would make you a commercial electric customer to the local utility company. You would be on a demand and energy rate, probably in the $10-12$ per kW range. In other words, it would cost you $1200-$1400 the first time you hooked up the charger each month and probably another $300-$500 in energy costs. Not sure where you save on fuel costs. If you used 20 gallons per day for 20 days that's about $1200 right now...Better check with your local utility before you purchase one of these vvanders....I don't think $6 per charge is even close to what it will cost. Maybe get an off peak rate but it will still be a lot more than $6. Plus they will probably make you purchase a larger transformer to service you load.
/ Unfathomable #45
Up here our UD starts demand metering at 100kW so if you stay under 100kW you don't have a demand charge. From there it's $4.50 kW peak, so I think the demand charges wouldn't be as large as you think.
Certainly worth considering if you have higher loads in conjunction but I don't think it'd be quite that high.
/ Unfathomable #46
Speaking of Unfathomable..
Thought you might like this...
It is some real cool... "Ironman" Tony Stark type stuff.. My boss was showing me this last week. My company has a project about to kickoff that is going to implement this... I don't get to be part of it though... :(
Microsoft HoloLens | Official Site
/ Unfathomable #47
Here it is, I found one.
I would buy a NH2 new hollands hydrogen powered tractor, I personally think hydrogen is the fuel of the future and I would be the one of the first farms to run hydrogen tractors and produce my own hydrogen.
That's the future I think, that tractor is only 106hp but it's 100% free of emissions and burns a renewal fuel source
Contrary to what is hyped up about battery powered machines and especially hydrogen fueled, they are not emission free. Except for electricity produced by wind power, there is always fuel used to generate electricity. Even wind power has at some point used energy to make the turbine, tower and blades and most likely that energy was from fossil fuel. FOR SURE burning hydrogen is emission free, just water vapor produced. But how was the hydrogen produced? It used electricity to separate water into hydrogen and oxygen. Then the hydrogen had to be compressed and transported to its usage point, another use of energy expended before it can be use to power something.
Hydrogen is a total waste of energy- electricity use to convert water to Hydrogen and Oxygen then compressed and shipped somewhere to be burned and turned back into water vapor. Anytime you use energy to convert a product into a different form of energy, you loose energy in the process. Better to just use the electricity to charge a battery-less loss that way. For this reason hydrogen will never be a viable alternative fuel in most of our lifetimes.
I don't think we could put up enough wind farm generators to replace all of the fossil fuel generators in the USA. If we for some reason lost all use of fossil fuels and were able to use 100% of capacity in wind generation, a lot of us would loose a lot of amenities. We would be lucky just to have lights, cooling and heating would have to go for most of us if not all.
Ethanol production is another energy consumer that I doubt gains any thing in the process. Likely it takes as much energy OR MORE to produce a gallon than it will provide.
Technology wise, we are just not there yet for alternative energy products. Perhaps someday in the future, but not now.
/ Unfathomable #48
ICE engine uses, in my estimation, about 5% of the energy that initially came from the ground. Battery powered electric motor, in this respect, beats ICE hands down. We should use hydrocarbons to make something more useful than burning it.
/ Unfathomable #49
Yeah, 4 hours of work, and 24 hours of charging time. OK not too good so far. We need about a 5 to 10 fold increase in battery capacity, and we need to be able to charge them up a bunch quicker... Good start but this tractor falls short. Keep working.
When they can charge for 4 hours and work 24 hours, then we'll have something!!! :)
/ Unfathomable #50
I'm not a "greenie". When I see all these alternative methods of power I think like a "greenie" though. For example, what's the carbon footprint of a wind turbine?
In regards to future technology. I'd like to see our tax money spent sponsoring innovation into a source we haven't even dreamed of yet. I don't appreciate it being spent on things we already know isn't the answer. :)
/ Unfathomable #51
You're way low there. Per Argonne National Lab study, the average refinery is about 85% efficient in producing gasoline or diesel.
Although traditional Otto cycle gasoline engines only have a thermal efficiency of about 20%, the variable valve timing and other advances have brought them up to 25 to 30% and the Atkinson cycle engines used in hybrids can get to over 35%. Diesels can be 40% or so.
If the electricity to charge the batteries came from a thermal power plant, it was probably 40 to 55% efficient and then there are transmission and charging losses.
/ Unfathomable #52
Certainly interesting. JD wants around 3K for a new motor for my E-Gator, and about that again for a controller. Yet, very basic stuff. No one ever talks about life cycle costs and it's probably more an important factor these days, than ever.
/ Unfathomable #53
I looked at several sources at internet (if you can trust them). Refined products gasoline and diesel will contain 68% of BTU of the crude at best. The number doesn't take into account energy used to make refinery work. Refineries recover a lot of energy (heat) to run the machinery but that covers only portion of the energy required. Considering energy spent refining crude the the refined products contain about 61% of the initial crude energy. ICE converts about 30% of fuel energy to useful work or about 20% of initial energy contained in crude. Now add energy used to get the crude and transport it to the refinery and energy used to deliver fuel to the gas station etc and you get quite low total efficiency number.
Modern combine cycle power plants are approaching 70% efficiency. Battery chargers are about 95% efficient, Li-ion batteries charge discharge cycle is nearly 100% efficient and electric motors are also highly efficient. In other words battery powered electric car converts about 90% of generated energy to useful work or about 60% of the energy contained in the fuel burned in the power plant. While electric power generation suffers similar fuel transportation and power delivery losses as liquid fuel the losses are most likely significantly lower. Therefore I think electric cars are significantly better users of energy resources.
/ Unfathomable #54
There's much more to it than what you stated. You have to consider what it takes to produce the electric car and what it's lifespan is, necessary repairs during that lifespan, etc. Carbon footprint.
/ Unfathomable #55
My bet is the carbon footprint is about the same as manufacturing of gasoline vehicle.
I am biased toward electric cars because:
1.) They are fun to drive. As one of the Tesla tester described it. They have implant flattening acceleration.
2.) No oil changes EVER.
3.) Even when we buy the energy at retail they are still way cheaper to operate.
4.) Cost of "fuel" is way less volatile than gas or diesel.
5.) They are quiet.
6.) They reached a driving range that makes them practical transportation for majority of our driving (I mean like 99% even though we live 12 miles from the closest grocery store and 45 miles from large city)
7.) The Middle East can keep their oil. Screw them.
8.) The hydrocarbon saved can be used to make something more useful than heat.
9.) They can have, potentially, better aerodynamics. They have flat floor, no induced drag by air flow through engine compartment etc.
10.) They don't depend on single source of energy (crude oil) but can be powered by PV, wind, water, nuclear, coal, NG, bio fuels etc.
11.) We make our own electric power. That I would love to use for myself instead selling to the utility for $ 0.035/kWh.
12.) Charging time and instant availability is not too relevant for us. We are retired.
/ Unfathomable #56
5.) They are quiet.
I appreciate your enthusiasm.
Maybe Google it.
/ Unfathomable #57
Maybe there are different ways of calculating refinery efficiency. I'm familiar with this Argonne Lab paper:
https://greet.es.anl.gov/files/petroleum-eff-13
It looks at all products from refineries, not just fuels and shows numbers just under 90%.
The best of the gas combined cycle plants just barely exceed 60%. Most of the electricity is produced in lower efficiency plants.
Also, unless there has been some breakthroughs, the battery charger is about 95% efficient and the charging process is about 95% efficient, resulting in less than 90% overall efficiency.
In general, I'm an electric car fan. I own two hybrids. However, I think we're still requiring $4 or $5 a gallon fuel to make full electric competitive.
40' High cube 6 door Single use Shipping Container (A64194)
40' High cube 6...
2009 International DuraStar 4400 Fuel Tanker (A62613)
2009 International...
2022 EZ-GO ELITE...
58in Wagon Wheel Bench (A65583)
58in Wagon Wheel...
UWS TBS-69 Truck Bed Tool Box (A64556)
UWS TBS-69 Truck...
25in Wagon Wheel Chair (A65583)
25in Wagon Wheel...
