Uneven cut with my bushhog
   / Uneven cut with my bushhog #1
LabLuvR
SC
Kubota MX5400
I've noticed of late that my bushhog is not cutting cleanly the whole width. There is about a six inch strip on the right side that is not cut cleanly like the rest. Is this a result of dull blades, or something else? Thanks!
   / Uneven cut with my bushhog #2
Is your BH a single blade or 2 blade.
If it's a 2 blade the blade could need sharpening.
If single or double blade it's also possible the deck could be bent where the bearing housing goes through so the blade isn't level when cutting. I would suspect the deck is bent.
Thanks, it is a two blade and I will look at it to see if the plate appears bent.
   / Uneven cut with my bushhog #4
I had a problem my brush hog was not cutting level about 4 inches on both sides. I changed the blades and the problem was fixed. I suspect the blades got bent as they looked really bad. Anyway worth a try.
   / Uneven cut with my bushhog #5
I think you might find that the uncut strip lines up with your right rear tire. It lays the grass over and unless your blades are very sharp or close too the ground it is hard to get that strip to cut.
   / Uneven cut with my bushhog #6
I agree on tire pushing un-cut material down. Have you ever tried reversing direction of travel? Sometimes reverse direction gives a better cut especially if one isn't utilizing 100% of the cutting width of cutter.
BUYERS PREMIUM & PAYMENT TERMS (A58017)
BUYERS PREMIUM &...
2019 DRAGON ESP 150BBL ALUMINUM (A58214)
2019 DRAGON ESP...
500 Gallon Poly Tank (A59076)
500 Gallon Poly...
202480 (A54757)
202480 (A54757)
2022 Horizon Trailers DH8BP-2 15ft 5 Ton T/A Dump Trailer (A55973)
2022 Horizon...
2013 HYUNDAI Veloster (A56859)
2013 HYUNDAI...
