Uneven cut with my bushhog
   / Uneven cut with my bushhog #1
LabLuvR
Gold Member
SC
Kubota MX5400
I've noticed of late that my bushhog is not cutting cleanly the whole width. There is about a six inch strip on the right side that is not cut cleanly like the rest. Is this a result of dull blades, or something else? Thanks!
   / Uneven cut with my bushhog #2
Is your BH a single blade or 2 blade.
If it's a 2 blade the blade could need sharpening.
If single or double blade it's also possible the deck could be bent where the bearing housing goes through so the blade isn't level when cutting. I would suspect the deck is bent.
Thanks, it is a two blade and I will look at it to see if the plate appears bent.
   / Uneven cut with my bushhog #4
I had a problem my brush hog was not cutting level about 4 inches on both sides. I changed the blades and the problem was fixed. I suspect the blades got bent as they looked really bad. Anyway worth a try.
   / Uneven cut with my bushhog #5
I think you might find that the uncut strip lines up with your right rear tire. It lays the grass over and unless your blades are very sharp or close too the ground it is hard to get that strip to cut.
   / Uneven cut with my bushhog #6
I agree on tire pushing un-cut material down. Have you ever tried reversing direction of travel? Sometimes reverse direction gives a better cut especially if one isn't utilizing 100% of the cutting width of cutter.
Liebherr PR736 LGP Crawler Dozer, S/N & PIN# 1155-17697, ID# 93501138, Turbo Diesel Engine, 13' (A59076)
Liebherr PR736 LGP...
John Deere 5075E (A53317)
John Deere 5075E...
WOOD GRABBER FOR MINI EXCAVATOR (A58214)
WOOD GRABBER FOR...
2017 Chevrolet Trax LS SUV (A55973)
2017 Chevrolet...
2010 Chevrolet Silverado 1500 Ext. Cab Pickup Truck (A55973)
2010 Chevrolet...
2005 TerraGator 8104 (A55302)
2005 TerraGator...
