LouNY
Super Star Member
- Joined
- Jul 4, 2015
- Messages
- 14,823
- Location
- Greenwich, NY
- Tractor
- Branson 8050, IH 574, Oliver 1550 Diesel Utility (traded in on Branson) NH 8160. Kioti CK2620SECH
After the meter base it will be up to your local electrical inspector as to what is allowed in your area.
I would assume that at the meter base you will have a main disconnect (breaker) which will feed a pair
of sub mains. Not knowing the amperage of the sub mains it's hard to say what would be next but
most places will allow URD direct burial cable, aluminum 2/0 is rated for 225 Amps direct bury but only
170 Amps in conduit.
https://www.wireandcableyourway.com...te-underground-secondary-distribution-cable-1
but just a quick check it looks like code may have been changed again, I'm seeing 4/0 aluminum for 200 amp feeders.
