Underground Air Line
   / Underground Air Line #1
Temp97
Western New York
My compressor is in my wood shop in the basement of my house. I would like to run an underground line about 50' to an outdoor woodshed. The idea is for conveince only. What type of material/line should I use?
Sarge97
   / Underground Air Line #2
copper line is good, easy to work with but expensive.
in industraial areas its either copper or screw pipe (black pipe) but can be galvanized.
that would be my second choice.
brining up the rear would be PVC. Which works, but suffers from a perceived safty problem should you ever hit it with something.
   / Underground Air Line #3
Sarge97
To be honest you know what I would do is use 1 1/4 pvc in the ground and just run 3/4 airline through it. That way down the road or if you have any problems you can just pull a new line through without digging it up again
Good ideas, I really like the idea about running a line thru a pipe in case something needs fix'n.
Thanks
   / Underground Air Line #5
Just don't go with to small a piece of tubing. I think black plastic waterline is an even better idea. Its nice smooth walled and you can get a seamless length fairly cheep
   / Underground Air Line #6
I have a small shed (12x12) about 60' from my house. Same deal, compressor in the basement, but wanted air in my attached garage and in the shed. I used copper pipe to get from the basement to the garage, and to the outside wall closest to the shed. Then I ran two 1.5" PVC conduits to the shed. I put 5/8" air hose in one and electric in the other.
It's been working fine for about 4 years. If something ever goes wrong with the air hose, I can replace it without touching a shovel.
Also, be sure to thread a pull line through the conduit as you glue the sections together. Not sure how you could do it afterwords. Someone told me that you can tie thread (sewing thread) to a tissue and suck it through with a shop-vac, then use the thread to pull a heaver string through. Never tried it, hope I never need to. ;)
Doug
   / Underground Air Line #7
Timber's suggestion sounds good, but the pvc will eventually get water in it. What will that do to the hose?
   / Underground Air Line #8
To get a thread thru a pipe, take a plastic pill bottle, remove top, drill hole in bottom, size is somewaht less than plastic pipe, knot thread in bottom of bottle, blow thru pipe using shop vac. Be sure to hang on to the the thread, it's like hanging on to monofilament with a 5 lb bass on it.. really wants to get away from you:eek:
   / Underground Air Line #9
Why dont you use the gray electrical conduit and glue it together? That should keep it watertight.
And I am thinking about something similar - I would like to pump compressed air to the pond for aeration and the route of plastic pipe and air house sounds good to me, thanks Timber.
I was thinking of keeping a good down hill angle towards the shed so that any water should drain at the end into the ground under the floor? Maybe...
2014 Peterbilt 384 T/A Wet Kit Day Cab Truck Tractor (A51692)
2014 Peterbilt 384...
2016 Nissan Altima 2.5 Sedan (A54815)
2016 Nissan Altima...
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
2021 CATERPILLAR 242D3 SKID STEER (A51406)
2021 CATERPILLAR...
2020 Exiss Escape 7306 LQ T/A Gooseneck Horse Trailer (A50322)
2020 Exiss Escape...
2018 KENWORTH T880 DAYCAB (A53843)
2018 KENWORTH T880...
